Tailgate latch hardware
Old May 6, 2024 | 10:00 AM
beartracks's Avatar
beartracks
Anyone replace the parts for the tailgate latch? I think the springs are dead on my latches. Not sure what I'm getting into on how to get the parts in/out.
Old May 6, 2024 | 10:18 AM
Rubiranch's Avatar
Rubiranch
I replaced mine and it works greats.
LMC truck tailgate parts
Old May 6, 2024 | 11:53 AM
beartracks's Avatar
beartracks
Did you have any trouble getting the rods where they needed to be to connect? Not sure if anything holds them in place when the spring plates are removed.
Old May 6, 2024 | 12:59 PM
Rubiranch's Avatar
Rubiranch
Not that I remember.
I also bought those plastic clips too.
Old May 6, 2024 | 01:20 PM
beartracks's Avatar
beartracks
Thanks a lot!
Old May 6, 2024 | 10:30 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Be aware that the welded in place internally square nut can break loose. See the R/H one in the pic?
Old May 6, 2024 | 10:44 PM
tbear853's Avatar
tbear853
To remove mine, when removing the OEM latch mechanisms at the ends, after the first of the square weld nut broke loose, I carefully and precisely as I could, determined and marked the inner tailgate surface for the center of the flat on the side of the square nut, then drilled (3/8" ID holes) into the nut's flat just enough that I could confirm the location and use a bit of weld to weld the nut to the tailgate there, filling the hole just drilled. Carefully avoided welding the bolt too. The weld heat expanded the nut and then the bolt was easily removed.
Didn't do it on my new tailgate, but I come close. If ever I need to undo the bolts, and they seem stuck, I will.
I did coat the threads with nickel anti seize.
Old Sep 5, 2025 | 08:48 AM
fatherdoug's Avatar
fatherdoug
Hello, beartracks. I just replaced my whole latch assembly with a kit from Auto Metal Direct. The kit is complete for the entire latching assembly, including the handle for about $150. They also have some you tube videos that are detailed for removal and installation. A couple of caveats, though. None of the nuts, bolts are included with the kit. Fortunately, all my nuts, bolts were still in good shape. I was missing two stake nuts on the tailgate which I couldn't find replacements for. Also the plastic retainers for the rods are inverted when shipped, so you have to squeeze the retainers out and turn them around. Good luck.
Bret4207
Jun 26, 2021 04:42 PM
rob17
6.7L Power Stroke Diesel
Aug 27, 2016 07:01 PM
bf5113
Aug 14, 2005 07:24 AM
ymurf
Mar 7, 2005 06:08 PM
douggant
Feb 10, 2004 01:03 PM
