Wheel Vendor Source 9.4
Old Sep 4, 2025 | 06:45 PM
Idaho Highboy's Avatar
Idaho Highboy
Veteran: Navy
Question Wheel Vendor Source 9.4
Hello FTE !
Curious if anyone has had a good experience with a company that makes wheels similar to the ones on this Bronco. Every once and a while I see some on a Bring a Trailer truck, but I'll research and (for example) the company is no longer in business. I think a set would go FABU on my Highboy, given the color scheme. Thanks !
- IH
Old Sep 4, 2025 | 07:23 PM
motorsickle1130's Avatar
motorsickle1130
I just searched the “oogle” with solid steel wheel 8x6.5 (my lug pattern), and had quite a few results, with a decent spread on Summit.
Old Sep 4, 2025 | 08:10 PM
Idaho Highboy
Veteran: Navy
Odd... went to Summit Racing and all it offered, filtered by year & model, was lug nuts. Will keep looking. Hoping someone already has a good experience to share.
- IH
Old Sep 4, 2025 | 09:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you want to find THOSE wheels (as in who made them, brand, manafacture ect...) just as these early Bronco folks. They are the 1000% best source of EB info. I bet you might end up talking to the guy that owns that very Bronco. Make sure to post that very pic. https://classicbroncos.com/forums/
Looks like stock steelies that have been recentered big time. Might have to just take a set of steelies and take them to a fab shop that does that kinda stuff.
Or check with Trail Worthy Fab, pretty sure they do recentering on 16.5 military bead locks. Which are 8 on 6.5 and fit your 3/4 ton lug pattern. And they have 16.5 tires... https://trailworthyfab.com
https://trailworthyfab.com/collectio...-hummer-wheels
Old Sep 5, 2025 | 09:59 AM
Summitracing's Avatar
Summitracing
SPONSOR
OP,
Those look like larger aftermarket steel wheels styled to resemble OE wheels. While we don’t have those exact wheels, we do carry the US Wheel 664 OE Series. For your 8 x 6 1/2 in. bolt pattern, the largest diameter available is 17", with width options of 8", 9", or 10".
If you’re interested, let us know your preferred width and we’ll help you dial in the right backspacing for your setup..
__________________
800-230-3030
www.Summitracing.com
truckdog62563
Sep 4, 2020 05:59 PM
191124x7
All Things Towing
25
Jan 8, 2019 09:53 PM
SolidCitizen94
Oct 27, 2013 03:36 AM
GuitarJesus
Jun 26, 2012 11:02 AM
