08 F450 Axle seal tool and ball joint part number
I have an 08 F450 I originally ordered spicer 2020315 kit for the truck but the ball joints are really small so I know I have the incorrect set.
I also purchased the OTC 6698 but the tool doesn't seem to go all the way down into the bore of the knuckle with nothing in the knuckle. I don't know if that's normal behavior or if I just have the incorrect tool.
Can I please get some help.
I have been emailing Autonation Ford all day they came in clutch with some part numbers.
Upper is BC3Z-3049-A
Lower is BC3Z-3050-D
The seals are still the same as the F350
Hub Vaccum Seal
Spicer-2023068
Ford-5C3Z-3254-B
Inner axle seal outside the axle tube
Spicer-2014835
Ford-AC3Z-1S175-A
Inner axle seal inside Diff
Spicer-2019816
Ford-EC3Z-3254-A
Axle Guide (not Spicer 53987) I am still on the hunt for this as mine were damaged removing the inner axle seals inside the differential.
Hub Vaccum Seal
Spicer-2023068
Ford-5C3Z-3254-B
Spicer-2014835
Ford-AC3Z-1S175-A
Spicer-2019816
Ford-EC3Z-3254-A
The following users liked this post:
I ordered the upper and lower and it appears they didn't come with the hardware. Do you happen to have the part numbers for the nuts and snap ring?
Fat Diesel
07-24-2011 07:12 AM
mechelement
10-12-2009 01:26 AM
