I was getting short to power on both rear ABS sensor circuits and finally traced the problem to the wiring harness connector that sits at frame level below the drivers side door. The connector had water inside and looks to have been shorting. I used some electronics cleaner and then a liberal amount of dialectric grease when reconnecting and the ABS light cleared itself.
Thanks again for the troubleshooting guide - it was a tremendous help!
