Abs problem
Old May 16, 2023 | 06:16 PM
Honey9723's Avatar
Honey9723
1st Gear
Abs problem
I have a 2019 f350 king ranch my abs light came on and I wasn’t getting communication to the ABS module. I replaced it and still wasn’t getting connection and now my ABS light is flashing.
Old May 16, 2023 | 07:42 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Harness issue somewhere maybe.
Have you scanned the code?
Old May 16, 2023 | 07:46 PM
RidgwaySD's Avatar
RidgwaySD
Not just a wheel speed sensor? How did you determine the abs module was bad?
Old May 16, 2023 | 09:00 PM
morehouse7's Avatar
morehouse7
https://www.ford-trucks.com/forums/1...h-forscan.html
Old May 23, 2023 | 09:44 AM
sparkobee's Avatar
sparkobee
2nd Gear
Hi there, You can use an ABS capable DTC scanner. it can scan codes present in the ABS. You can visit the YOUCANIC article about the Ford ABS light to know more about common causes of why ABS light turns on. It also includes how to reset it. I hope this can help!
nateairman
May 24, 2021 04:40 PM
beartracks
Jun 19, 2011 11:42 AM
cordespc
1997 - 2003 F150
Apr 14, 2007 11:29 AM
