C6 vacuum modulator
Old May 2, 2024 | 11:44 PM
Jeff Wecker's Avatar
Jeff Wecker
C6 vacuum modulator
I was underneath looking at my vacuum modulator on my 1973 F100, and noticed it has 2 vacuum hose ports. If I ever had to replace it, could I use a C6 modulator with just one hose port?
Old May 3, 2024 | 10:07 PM
mark a.'s Avatar
mark a.
Yes you could.
Old May 4, 2024 | 09:12 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
My $0.02 that I copy and pasted from mikeo0o0o0 years ago.
"Check the vacuum modulator and the line that goes to it. Check the line for kinks or other problems, make sure it hasn't come off. If the line checks out, take the line off where it connects to the modulator. If trans fluid leaks out, its bad. If no fluid, it still could be bad. They're simple to replace, disconnect the vacuum line, remove one bolt that holds the clamp in place and the modulator comes out. It has an o-ring seal.
Modulators are identified by the color of the stripe. Pretty much the "go to" one is the black stripe. If they don't show that one in the catalog, go with the green stripe. Avoid the pink stripe. That one is a dual diaphragm version that has two vacuum line going to it. If by chance you have one of these, replace it with one of the other two and use the vacuum line that goes to direct manifold vacuum, cap the other line.When you pull the modulator out, be careful. There is a pin that goes in the modulator. Sometimes it comes out with the modulator, sometimes it stays in the tranny. If it comes out, don't lose it."
Old May 4, 2024 | 06:10 PM
Jeff Wecker
Thanks for that info, I'm going to order one with the green stripe. Not sure what color stripe the one I have now is, as it's covered in road grime, But it does have 2 vacuum ports on it.
Old May 5, 2024 | 08:47 AM
FuzzFace2's Avatar
FuzzFace2
I just want to know?
What dose the other vacuum line go to / do?
Is it for something like spark control?
Dave ----
Clinton N
1978 - 1996 Big Bronco
Jul 7, 2020 09:21 AM
genscripter
Sep 13, 2014 06:23 PM
wtc2792
Feb 26, 2012 07:14 PM
ranger pat
Jun 19, 2001 06:44 PM
