If you have this truck but somehow still dont have an oxy-fuel torch then go buy one now.
for this job you will need to use an impact screwdriver as mentioned above and also lots of penetrating lube and heat.
if it still wont move when hot then smack around it with a hammer to shock the rust loose.
