2017 Sync 3 Version
Old Apr 30, 2024 | 09:40 PM
jaso's Avatar
jaso
7th Gear
2017 Sync 3 Version
Hello all,
I have a 2017 F-350 Lariat with Sync 3 (no nav) that is running 3.0.20204. According to the "check update" feature and owner.ford.com, this is the latest version for my truck. I've seen the references to CyanLabs and have read that there are quite a few newer versions of the software available.
I'm trying to wrap my head around all of this. Is 3.0.20204 the latest that Ford supports / recommends for my model year or am I just hitting a bug? It seems that MY2020 introduced a design change - could that be what I'm seeing (2017-2019, 3.0; 2020+, 3.4)?
I'm considering the 3.4 updates because recently CarPlay has started acting goofy, plus I'm a computer geek by trade so my "keep it upgraded" nerve is twitching.
Thanks for any insight you have.
Regards,
j
Old Apr 30, 2024 | 10:27 PM
4wd6.7L's Avatar
4wd6.7L
My 2019 has the Sync version that you have, but it says update available to 3.0.23219.
Cyanlabs enables you to upgrade to 3.4, which didn't start until 2020MY.
Old May 1, 2024 | 12:46 PM
jaso's Avatar
jaso
7th Gear
Thanks for sharing!
Old May 1, 2024 | 02:23 PM
Phillbo's Avatar
Phillbo
how do you get this upgrade?
Old May 1, 2024 | 04:34 PM
4wd6.7L's Avatar
4wd6.7L
You mean Sync updates? You can check for Sync and Navigation updates here https://www.ford.com/support/sync-maps-updates/
It will tell you what, if any updates are available and what options you have to download them.
Old May 2, 2024 | 08:38 PM
Keith Griffin's Avatar
Keith Griffin
Jaso,
I have a 2017 F-250 that had Sync 3.0 on it when I bought it in '20. I took a leap and jumped to 3.4 with it and have been happy since then. My last update was with CyanLabs updater, but the original jump I did using the following thread to get me started:
https://www.f150forum.com/f118/upgra...ctions-458828/
I realize that's over on the F150 forum, but the instructions work for the SD's as well. It was well worth the effort to do it. I have even update my maps to newer than the 1/14 that I had originally. CarPlay works pretty good with it and now that I have a wireless CarPlay adapter, it's even better.
Good luck with it!!!!!
Keith
Dan Lockwood
May 31, 2021 10:21 PM
Lognomore
Aug 11, 2020 08:30 AM
Gary F
Feb 20, 2020 11:53 AM
Roadhunter
Oct 31, 2018 12:24 PM
backbeat
Sep 17, 2013 01:13 PM
