O2 sensor bank2 sensor 2
Old Apr 27, 2024 | 06:28 AM
BAD RONALD's Avatar
BAD RONALD
Confirmed code PO157 and pending code PO056 on a 2017 3.5l F150 at 50,300 miles. Yesterday the engine was skipping a little on a cold start at high idle and then hunted between 8000 and 12000 rpm.
Any member have experience with this condition and repair?
Old Apr 27, 2024 | 10:25 AM
GlueGuy's Avatar
GlueGuy
We had an O2 sensor "fail" several years ago. As it happened, it was not actually the sensor, but a rodent had gotten to it and chewed off the wires. Right down to the sensor itself. It was an expensive repair for such a simple problem.
Old Apr 28, 2024 | 06:00 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I had to replace all four sensors on my 2011. No issues with it running any differently but it was flashing a code. Started with one going bad then next, I had them all done.
Old Apr 28, 2024 | 09:59 AM
BAD RONALD's Avatar
BAD RONALD
Interesting that more than one of the sensors failed. Seems that for the '17 MY O2 sensor failure is not common, but overall there ARE way too many malfunction codes thrown by bad sensors.
Looks like the bank 2 sensor 2 is on the driver's side, rearward of the cat and accessible. Hopefully road salt hasn't frozen the thing solid.
I did see online that one cause of O2 failure is contamination due to dirty air filter. This truck is typically driven on dusty rural roads so an air filter inspection/change is overdue anyway.
Will report on what I find.
Old Apr 28, 2024 | 01:22 PM
BAD RONALD's Avatar
BAD RONALD
Air filter was clean and I bet the sensor itself will also be. The driver- aft sensor wire shows damage from contact with the forward driveshaft. Source of MIL identified.
Size of sensor is ⅞'' measured with an open end wrench.
Hope this helps somebody some day.
03fjuan50
1997 - 2003 F150
Nov 20, 2015 06:55 PM
mizzourover
2009 - 2014 F150
Apr 14, 2015 09:28 AM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
BrianA
1997 - 2003 F150
Jul 17, 2012 06:14 PM
jderry78
Sep 29, 2007 07:00 PM
