shifting issue
Old Apr 27, 2024 | 04:33 AM
gweedo295's Avatar
gweedo295
shifting issue
Good morning, been a minute since I posted last. after almost 20- years the highboy got the highboy back on the road a few months ago and its running great. question about shifting.
1. I need to let off the accellerator slightly before it will shift gears, and depending how fast I'm going it hits a bit hard. Don't know if it has a shift kit or not. Modulator??? I did service the trans and it was very clean.
2. If I shift it manually it shifts smooth.
3. It goes into park but I need to make absolutely certain its in park and I ALWAYS makes certain the parking brake is on. it slipped out of park one time. is there an adjustment for this? worn parts?
Thanks
Old Apr 27, 2024 | 05:02 AM
charlie g's Avatar
charlie g
FTE Community Team
sounds like a issue with stuck valve or valves in the trans valve body , or if it has a kick down cable/rod out of adjustment
Old Apr 27, 2024 | 08:02 AM
gweedo295's Avatar
gweedo295
Thnx I should have mentioned it. I don't have the kickdown hooked up right now, I put on and edlebrock but I don't think a kick down will make a difference with the normal driving, it will shift I just have to let off the accelerator a little to allpw it to happen.
Old Apr 27, 2024 | 02:44 PM
FuzzFace2's Avatar
FuzzFace2
If it has a Modulator pull the vacuum hose off it at the Modulator and see if there is any ATF there.
If so change it out. I think there is a colored band on it you will need to get the same color one.
Also watch when you pull it as there is a metal pin that may fall out and needs to be reused with the new valve.
Are you sure the ATF level is right?
From sitting the valves in the valve body could be gummed up and seals dried up. May get better with miles?
Dave ----
Old Apr 27, 2024 | 03:54 PM
gweedo295's Avatar
gweedo295
Thnx, I’m going to pull the modulator. The level is good, I cruised slow a couple miles at a time knowing the clutches would be dry.
then I serviced it with new fluid n filter which was very clean. Going to change cooler lines n inline filter as well.
Old Apr 28, 2024 | 11:13 AM
Old Guy F-250's Avatar
Old Guy F-250
I just have to ask..
Not sure it is fully in park.
Are you sure the shift linkage is adjusted correct??
Old Apr 28, 2024 | 06:02 PM
gweedo295's Avatar
gweedo295
I have to really push it up into park. One time I didn’t have e brake on. Jumped from outside n it jumped into gear. Bent drivers door forward after hitting my utv. So now I make sure e brake is on
Grampa jepp
Jan 7, 2018 09:19 AM
640 CI Aluminum FORD
2009 - 2014 F150
Nov 14, 2011 07:55 PM
Dvandy21
Jul 24, 2011 06:49 PM
04F-250mark
Jan 29, 2009 09:24 AM
reel_scream
Oct 18, 2004 08:58 PM
