Instrument Cluster Voltage Regulator
Old Apr 25, 2024 | 03:23 PM
Centennial F100's Avatar
Centennial F100
I have been working through and checking my instrument panel gauges and getting issues sorted out. I am going to be replacing instrument panel bulbs with LED's, mainly to get some more brightness. I am wondering if while I have the cluster out, should I bother replacing the ICVR. It appears to working fine based on how the gauges are operating, so should I leave sleeping dogs lie and not change it? If I were to change it are there any pros / cons between the solid state ones and the original bi-metal type?
Old Apr 25, 2024 | 07:08 PM
RTT's Avatar
RTT
I do not know , my opinion is solid state all the way...........if it is from a reputable dealer , look for reviews on the SS regulator , & working with LED's
Old Apr 25, 2024 | 10:22 PM
silverflash's Avatar
silverflash
Don't know about which one would work better, but since I had the instrument panel out when I installed the red, green and white LED lamps, I figured it would be worth it to go with a modern ICVR. So far, it sure is nice to see the improved lighting over the 56 year old lamps on my '68.
Old Apr 26, 2024 | 05:09 AM
Crop Duster's Avatar
Crop Duster
The difference between the original electromechanical IVR and the solid-state ones is the original IVR puts out 12V until it warms up, so the gauges react faster on startup. The solid-state ones put out a constant 5 V, so it takes the gauges a little longer to get where they are going.
If you change IVR's to either type always bench, check them before you install it. The solid-state ones are all made in China and can be DOA or putting out the wrong voltage.
Old Apr 26, 2024 | 09:12 AM
Jim_K's Avatar
Jim_K
When I had the cluster out in my '68 I replaced the IVR just as a matter of course. I mean, as long as you're in there....
Old Apr 26, 2024 | 02:53 PM
RTT's Avatar
RTT
evidently the IVR made Ford gauges work better than other companies , because other gauges did not have variable option
Old Apr 27, 2024 | 09:45 AM
Crop Duster
All the gauge systems, Ford, Chrysler and others are actually the King-Seeley system used up thru the 1970's and maybe later. It has been around forever. The original senders up to at least 1966 will have a stylized KS on them.
Chambers777
Jun 19, 2022 04:18 PM
Oliver Herting
Jun 17, 2018 05:14 PM
penn
Dec 19, 2002 01:06 PM
