Sponsored by: Real Truck
is this compression test bad?
Old Apr 24, 2024 | 08:20 PM
Kadynf46's Avatar
Kadynf46
Trailering
Hello I have a 2001 f250 with a 7.3, truck starts and runs. Idles a little rough but not super noticeable to a beginner like me. It has a lack of power. I know it’s hard to read so here’s what I got. 1. 405 3. 405 5. 400 7.425 2. 400 4. 320 6. 370 8. 340
Old Apr 25, 2024 | 07:11 PM
'89F2urd's Avatar
'89F2urd
did you squirt a little oil in the cylinder before doing the test? Are you testing through the glowplug hole, or injector hole?
Old Apr 25, 2024 | 07:19 PM
Kadynf46's Avatar
Kadynf46
Trailering
i didn’t squirt any oil into the cylinders before doing it. And I’m testing through the glow plug hole. What does squirting oil into it do?
Old Apr 25, 2024 | 07:21 PM
'89F2urd's Avatar
'89F2urd
wet cylinders give you a more accurate and consistent compression reading, mimicking the conditions of actual running at full rpm. Give that a shot, doesn't require much. Squirt some in, turn it over without the compression tester in place so that the oil slings around without igniting, then run the test
Old Apr 25, 2024 | 07:24 PM
Kadynf46's Avatar
Kadynf46
Trailering
Okay thanks! I’ll give it a try this weekend. I’ve been trying to troubleshoot this thing for a while now and can’t figure out what’s wrong, I feel like compression isn’t my problem though. I’m just getting this step out of the way since I haven’t done it yet. Do you know much about these 7.3’s?
Old Apr 25, 2024 | 10:01 PM
'89F2urd's Avatar
'89F2urd
yea, you should get a scanner if you don't have one already. Search "7.3 scanner" to pick one that is right for you, then come back for testing suggestions....although the basic is high pressure oil at crank and idle. misewell figure out your compression though, since you have the glow plugs out.
Old Apr 26, 2024 | 08:35 AM
redford's Avatar
redford
FTE Leadership Emeritus
On the surface, no. Those aren't great numbers. The basic idea is that you want all values within 10%.
If you give a cylinder a squirt of oil, and the number comes up, that is a good indication that the rings are worn and not sealing well.
99f350cclb
22
Dec 17, 2021 11:42 AM
lght1
Oct 22, 2013 02:07 PM
93F250HD
May 16, 2010 07:33 PM
KoolFord1
Feb 12, 2009 02:41 PM
venom69
Jul 18, 2004 01:02 AM
