odd compression test results
Old Apr 21, 2024 | 09:40 PM
Will104's Avatar
Will104
Just pulled my engine due to a front timing cover leak under the hpop and head gaskets, coolant blowing out the Degas bottle on occasion and soot in the coolant. So I decided to do a compression test while the cab was in the air before I pulled the engine. Engine is 2.5 year old Ford reman with about 30k on it. Using a brand new Mityvac Digital guage and lang adapter. being that my big Ashcroft and nice OTC adapter grew legs.
Cylinder 1 367 (trans was in gear, cab hit the stub when I was lifting it realized it on cylinder 3)
Cylinder 1 383 wet
Cylinder 3 434
Cylinder 5 426
Cylinder 7 443
Cylinder 2 425
Cylinder 4 426
Cylinder 6 425
Cylinder 8 319
Cylinder 8 538 wet (maybe too much oil)
Back to Cylinder 1 455 wet
Back to Cylinder 8 437 (Dryish after after several rotations retesting cylinder 1)
Back to Cylinder 1 438 (Dryish after after several rotations retesting cylinder 8)
Any of you guys have any thoughts on these results?
Old Apr 22, 2024 | 09:04 AM
glovemeister's Avatar
glovemeister
Do you have an o-ring on the lang adapter? It doesn't include one.
I suspect cylinder 1 and 8 you also didn't have the compression tester in all the way. Are all the glow plugs out? Are you cranking by hand or with a bar?
Old Apr 22, 2024 | 09:43 AM
Will104's Avatar
Will104
Yes mine did include an o-ring and I even got extras just in case (Last time I did a compression test on a 7.3 I had my OTC adapter and the o-ring only lasted a few cylinders). I spun the motor using the starter while the motor was still in the chassis with all the glow plugs out. And it was threaded all the way in til the o-ring was tight against the cylinder head.
Old Apr 22, 2024 | 05:42 PM
Will104's Avatar
Will104
I think I figured out the odd results, the truck was sitting for about 4 months so it took a bunch of rotations to get oil back around the all the rings set in the cylinders is what my best guess is.
yknotgo
Modular V10 (6.8l)
60
Oct 21, 2024 08:52 AM
Christmas
Feb 13, 2023 08:47 PM
cjakc21
2009 - 2014 F150
Nov 11, 2018 12:35 PM
obscurity
16
Aug 30, 2014 03:29 PM
fyrmn681
Escape & Escape Hybrid
Jan 14, 2008 11:45 AM
