Aerostar Ford Aerostar
Brake Lines
Old Apr 21, 2024 | 12:59 PM
mediaman67's Avatar
mediaman67
Brake Lines
Hi all
Does anyone know if someone makes a brake line kit, pre bent for the 3.0L Aerostar shorty? she's an 89
I just did my Navigator and it was nice to have everything pre done like that, plus they are stainless and should last a long time
They are original so I think 35 years - I got my money out of those - I know if I try to replace the calipers and hoses, they will prob just fall apart, so I might as well do everything including a new master too.
Thanks
Old Apr 21, 2024 | 11:19 PM
xlt4wd90's Avatar
xlt4wd90
Unfortunately, I have not been able to find pre-bent SS brake lines for the Aerostar. It was just not a popular enough car for vendors to make something like this for it.
If you live in an area where they salt the roads in the winter, I can see corrosion eating away at the stock steel lines. Otherwise, with the proper tools, you would be able to remove and replace the 3 flex lines on the car without damaging the hard lines.
Old Apr 26, 2024 | 11:19 PM
99f350sd's Avatar
99f350sd
Nope nada get the copper ni in coated version.
Old Jun 28, 2024 | 07:19 AM
sittinguy's Avatar
sittinguy
Do a close inspection for rust on the current ones. I legit had a rear line blow out a couple years ago on a panic brake. I was about an inch from crashing bad.
Old Jun 28, 2024 | 09:34 AM
mediaman67's Avatar
mediaman67
I guess my only real option is to buy a reel of the coated copper line and just bend them...
I just feel like everytime I drive her, Im asking for this to happen - it's scary when a line pops for sure.... and yes, I do live in the NorthEast - I dont drive her much in the snow but sometimes, and over the years, yeah, corrosion is real for sure...
Any recomendations for line size, etc - 3/8"? Fittings? - are the masters to the block bigger than the lines from the block to the hoses?
Thanks
Old Dec 11, 2024 | 05:49 PM
colinmcc's Avatar
colinmcc
Thanks
Did you ever find out the pipe diam and the thread(s) on the fittings? I need to do the same to my 95 4.0 AWD/ Thanks.
Old Dec 12, 2024 | 10:33 AM
DFord's Avatar
DFord
I answered your question in the other post you created.
99f350sd
Mar 26, 2023 10:21 AM
Basil17
May 22, 2022 01:12 PM
98F150on33s
1997 - 2003 F150
Nov 16, 2014 09:46 AM
The Grinch
Oct 17, 2004 04:37 PM
