4x4
Old Apr 29, 2024 | 04:08 PM
manicmechanic007's Avatar
manicmechanic007
The 97 service manuals will have your truck in them
Get those
Get the EVTM too
Old Aug 25, 2024 | 12:54 PM
samuel4wolfpack's Avatar
samuel4wolfpack
I have a 1996 F250 4x4 with the 5.8, zf5 and dana 50 as well.
I saw this socket for the spindle on Amazon, it looks like there are some good product reviews on here about this socket being used on the dana 50.
Amazon.com: Powerbuilt Spindle Nut Socket, Removal Spindle Nuts, 4-Lug, Dodge, Chevy, Ford, GM Trucks, Hub Sockets, Truck Repair Tool - 648477 : Automotive Amazon.com: Powerbuilt Spindle Nut Socket, Removal Spindle Nuts, 4-Lug, Dodge, Chevy, Ford, GM Trucks, Hub Sockets, Truck Repair Tool - 648477 : Automotive
Old Oct 31, 2024 | 06:13 AM
Davidwillis's Avatar
Davidwillis
Transmission cooler lines
Originally Posted by Davidwillis
Hey fellas I just bought a 1997 Ford F250 HD with automatic four-wheel drive. What do I need to know about this system any weaknesses or particular maintenance issues for example. Thank you
i need to replace my transmission cooler lines but i'm having a hard time finding the upper line. Any suggestions? I read somewhere on this forum that someone suggested just blocking the lines off. This truck is just a farm truck and will not be hauling heavy loads any distance at all. Is that advisable? What is the best way to do that? Thanks fellas.
Old Oct 31, 2024 | 06:51 AM
manicmechanic007
Do not block the lines off
Repair them if you cannot find a new one
AutoZone has transmission cooler line in both sizes.
Just replace the leaking rubber sections and use bulk 3/8 metal fuel line for the metal sections
We used to have to fabricate them from bulk tubing the hard way
Old Oct 31, 2024 | 07:01 AM
Davidwillis
Thanks very much
Old Oct 31, 2024 | 07:31 AM
JJF20's Avatar
JJF20
Measure the lines, they should be 5/16.
I believe Inlinetube has them now. Stainless steel.
If making your own, NiCopp / nickel copper tubing is very easy to work with.
Old Oct 31, 2024 | 07:47 AM
AuroraGirl's Avatar
AuroraGirl
if you desire to upgrade to 3/8 for better flow, heres the part number for the fitting (vital you have the check ball)
Old Oct 31, 2024 | 08:52 AM
manicmechanic007
Wow, I think they are 3/8
Just take an open end wrench and check the size
Timothy Grabowski
Apr 21, 2024 10:13 AM
caspermj
WTB - Ford Trucks & other vehicles
Feb 13, 2013 10:22 AM
jetta4
Feb 4, 2004 07:16 PM
