1978 - 1996 Big Bronco
Codes 211 and 212, '94 Bronco
Old May 5, 2024 | 01:55 PM
McLeod's Avatar
McLeod
First, I would look to see if the number above the starter is an F4 block. If so, it is a roller block
If it is, look under the lower intake to see if you have the spider w/ the eight legs to hold down the dog bones used to retain the lifters
To see what the distributor gear is made out of, if you have one already and because some are hard to tell by looking, you can lightly touch an inconsequential area of the gear (not the teeth) to a grinder to see how it sparks.
Cast is usually rough and steel is usually smooth but this doesn't always hold true.
You can look for colored marks on the gear:
Yellow / orange - indicates steel
Blue / purple - indicates iron
Old May 6, 2024 | 06:13 AM
Justin_S987's Avatar
Justin_S987
So I scurried outside and shimmied under my bronco to see what block I have andbit is indeed an F4 series.
I know I the distributor I bought and installed has an iron gear because I chose it as a precaution since I was trying to get it back on the road.
Old May 7, 2024 | 04:31 AM
manicmechanic007's Avatar
manicmechanic007
You could just buy a new steel gear for your distributor
Good luck
Have fun
With prices like these, I'd be at the junkyard pulling the distributors out of a few Mustangs and getting their steel gears
Old May 7, 2024 | 11:52 AM
McLeod's Avatar
McLeod
You can get brand new distributors with steel gears and a new cap and rotor on Rockauto for $60 to $90 (plus shipping)
Also, without looking further, you will be assuming you also have a roller cam and it is likely you do but some weren't.
Also, never know what a rebuild has it.
b4hntn
Jun 23, 2008 12:22 PM
msautry
Electrical Systems/Wiring
Jan 7, 2005 03:58 PM
msautry
Jan 4, 2005 09:27 PM
msautry
Jan 4, 2005 09:25 PM
B.A.D. Bronco
Jun 25, 2004 12:16 AM
