Mustang or Cop Car
Old Apr 19, 2024 | 07:17 PM
RTT's Avatar
RTT
Exclamation Mustang or Cop Car
The name of the cop car escapes my BRAIN @ the moment & Mustang or Mustang II maybe front end suspension upgrades are very popular
When the swaps are made to a F100 truck do they keep the car rims/wheels . Are car rims strong enough
I wonder if a 1969 front disc brake conversion will fit a 1971 F100
Old Apr 21, 2024 | 06:13 PM
FuzzFace2's Avatar
FuzzFace2
Cop car = Crown Vic
On the wheels it depends because the CV wheel pattern is different than the rear wheel truck pattern.
Also I think the tracks are different between the CV front and truck rear.
Some swap a full CV frame under the cab & bed from the truck and use the CV wheels or after market with the CV pattern.
Or they swap in a 8.8 rear axle that has the CV pattern and use the CV wheels or after market with the CV pattern.
As for strong when the CV suspension or full frame is used the truck will not be used as a truck it is a cruiser.
But I dont see any issues running the CV steel wheels as they are strong enough for that heavy CV car.
If you want to haul stuff in the bed keep the trucks suspension and save your money.
Dave ----
Old Apr 22, 2024 | 09:31 AM
uzikaduzi's Avatar
uzikaduzi
the crown vic swaps seem pretty nice and inexpensive until you start adding up the changes you need to make and replacing wear parts while doing it.
if you're considering it, it might be worth looking at the QA1 kit... its not cheap, but likely not too much different than what you'd be all in one a crown vic swap and you can keep your 5 on 5.5 wheel pattern
Old Apr 23, 2024 | 09:40 PM
RTT's Avatar
RTT
...Thank-you both...........I found a 1969 Mustang disc brake conversion for non power disc drums . How do you think this will work on a truck ???
Old Apr 23, 2024 | 11:59 PM
85e150's Avatar
85e150
No. Single piston, small diameter rotors, "wrong" bolt pattern for a truck.
Are you going to do a front suspension swap or just a brake update?
The Mustang II kits can be ordered with whatever pattern and brake you want. They are not salvaged items, they are purpose made kits based on the MII design.
NCMike
Mar 2, 2020 01:14 PM
1OldFordMan
WTB - Ford Trucks & other vehicles
20
Feb 14, 2010 03:10 PM
Fomoko1
54
Sep 22, 2008 10:17 PM
Marc150
General Automotive Discussion
May 4, 2005 10:51 PM
