What Is It????
Old Nov 25, 2003 | 08:07 PM
stgdive's Avatar
stgdive
Question What Is It????
The Lever above the shift linkage on the transmission.
I'm currently trying to find the reason my tranny tries to pop out of gear on high revs. This lever could be the answer, i don't know.
Any ideas? What holds the transmission in gear during normal use.
My modulator had been replaced prior to my purchase of this truck.........could it be it was installed wrong. What exactly is it's purpose. Please................these little gremlins are driving me nuts.
Old Nov 26, 2003 | 01:20 AM
NM5K's Avatar
NM5K
Depends. Some have detent ***** to lock. Make sure the linkage is correct. In some cases, if it's out of whack, it can damage the tranny. Ultra critical on the AOD's...Check your motor and tranny mounts. Make sure the engine isn't jumping around when you goose it. The shift linkage is probably ok if it's never been messed with, but something to consider. MK
zalinth
Nov 1, 2016 04:58 PM
JaySVX
Aug 26, 2016 09:03 AM
Dirtyape
Apr 29, 2014 02:43 PM
erkmadhatter
Escape & Escape Hybrid
Aug 16, 2012 11:26 PM
GreatNorthWoods
Jul 6, 2010 02:35 PM
