Battery dies, voltage doesn't charge
Old Apr 16, 2024 | 10:51 PM
awesomeobs's Avatar
awesomeobs
4wd Low
Hey all, I recently obtained a 1992 f150 with a 4.9 i6, 5 speed manual. It drove great until today, when the dash started not working and I noticed that the battery voltage was very low. I thought it was an alternator, and after replacing it doesn't seem to fix or charge the battery. I took it to orileys to see if they could test it, and they said it was a voltage regulator issue. The alternator is new and so the internal regulator I assume is still good, but I could not find the external regulator. Where in the hell is this thing? Could there be anything else causing the issue?
Old Apr 17, 2024 | 02:58 AM
My4Fordtrucks's Avatar
My4Fordtrucks
You answered your question. The regulator is in the alternator. I assume you have a 2G alternator so did you replace the connector pigtail when you replaced the alternator? Did you buy the alternator from O’Reilly’s?
Old Apr 17, 2024 | 07:16 AM
manicmechanic007's Avatar
manicmechanic007
You might have burnt up the fuse link wire when your alternator crapped out?
Or a short took out the fuse link and the alternator is still okay?
Check the big wire on the rear of the alternator for voltage
Yes, those alternator connectors melt, replace it
Wiggle the connector with the engine running to see if a bad connection exists
Good luck, have fun
wagaskyc
19
Jan 15, 2023 05:18 PM
Truck4SF
Jun 20, 2022 04:19 PM
darknight1028
Feb 7, 2011 04:57 PM
wickedklown83
Mar 10, 2010 05:46 PM
thuggishruggish3000
Jan 12, 2004 01:56 PM
