bored 302
Old Nov 25, 2003 | 07:22 PM
f100guy's Avatar
f100guy
bored 302
i built a 302 not to long ago it should have around 400 miles on it. smoke comes out of the oil filler on the valve cover barely. when you push the gas a little it goes away probably sucking it back in but i don't know. it is bored 60 over. i heard from an ignorant shevy freak that if it is bored 60 it is supposed to smoke a little. i said i don't think so. the only smoke that comes from my pipes is black since i think i need colder spark plugs. that is only when it is cold when i rev it up though. i have no lack in power so should i be worried about the smoke from the valve cover or not.
Old Nov 25, 2003 | 08:52 PM
TheWiz427's Avatar
TheWiz427
Check your pcv valve it might not be the correct one.
Just my 2 cents!
Old Nov 25, 2003 | 09:20 PM
f100guy's Avatar
f100guy
which one should it be this motor is totally unstock except for heads, crank and rods. it has a 1406 edelbrock carb where is the pcv supposed to hook up at. to the big port in the front of the carb. i have a triangle air cleaner from edelbrock and i have the pcv hooked to the air cleaner which is probably not the right place. the new valve that i bought has to ports it comes with a plug i have it plugged.
Old Nov 25, 2003 | 09:24 PM
f100guy's Avatar
f100guy
it has 2 ports on the pcv valve one i have the hose to and the other is plugged
Old Nov 26, 2003 | 07:31 AM
TheWiz427's Avatar
TheWiz427
Does it have a large and small fitting? If so cap the small one. The big port in the front of the carb is fine as long as it is full vacum.
Old Nov 26, 2003 | 08:30 AM
f100guy's Avatar
f100guy
i am not sure but i know the fitting has strong vacuum all the time.
f100guy
39
Oct 10, 2023 07:04 AM
madrox
Jun 11, 2010 01:00 PM
shorebird
18
Jul 4, 2009 11:52 AM
53OlderThanMe
Aug 21, 2008 06:24 PM
beaver24
1978 - 1996 Big Bronco
Oct 20, 2003 09:36 PM
