6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Injector Trouble Really Need help
Old Apr 16, 2024 | 08:21 AM
Dgthomas67's Avatar
Dgthomas67
I have a 2008 F450 6.4. 1st I got a Code P1552. Which from what I understand is Injector 2 problem. (If I would let the truck idle for a while before driving it it would do ok) So I had my mechanic Changed all the injectors on the Driverside please those little fuel lines and the Wiring harness for the injectors under the valve cover. I thought since he was going to be in there change them all and the fuel lines and the wiring harness. I ran great for about 2 weeks. Now I am getting a P0202 and letting it idle dont work. What is the difference between P1552 and P0202. Also Can I change the Wiring Harness from the ficm to the injector harness on the driver side only. The funny thing is when it is idling bad if I clear the code while it is idling using my edge monitor it starts idling right but then if I drive it it instantly starts messing up again. and clearing the code while driving it does not fix it at all.
Old Apr 18, 2024 | 04:49 PM
redford's Avatar
redford
FTE Leadership Emeritus
Thread moved to 6.4L PSD engine forum.
Good luckvwith your repairs.
Old Apr 20, 2024 | 09:17 PM
DieselDenny's Avatar
DieselDenny
Is the truck fully deleted?
Porrepair
Oct 25, 2023 11:48 AM
Excursion8827
Sep 20, 2022 02:55 PM
Gagew90
Jan 5, 2010 12:28 AM
pidford
May 3, 2005 02:27 PM
