Injector woes
Old May 3, 2005 | 06:31 AM
pidford's Avatar
pidford
Thumbs down Injector woes
I put remans in my 97 psd this weekend and now my truck seems like it has more of a miss in it then before. The tailpipe seems like it is staying damp right at the tip of it now also, but I don't know wether it is unburnt fuel or oil. Anyone got any suggestions. We all know how easy those are to test or diagnose.
Old May 3, 2005 | 06:49 AM
Kwikkordead's Avatar
Kwikkordead
These engines are notorious for problems with the wiring harness inside the valve cover and also the plug/s.
Old May 3, 2005 | 08:21 AM
barebackjake's Avatar
barebackjake
ditto what kwik said.
check all your wiring harness for the injectors.
Old May 3, 2005 | 09:13 AM
barebackjake
are you sure the same code injectors went back in the truck??
Old May 3, 2005 | 02:18 PM
pidford's Avatar
pidford
Question
Yeh, they were the same code injectors. What is the best way to check the wires on the injectors? Is there a special tester to use on them?
Old May 3, 2005 | 02:27 PM
Kwikkordead
Unfortunatly the valve covers have to come back off to do a visual. I recommend just biting the bullet and going down to the International dealer and buying the harness's and valve cover gaskets and hold down clips. I replace mine on my '99 for a burned out glow plug wire that had shorted against a push rod. The injector wires were ok looking. Well it ran better once I got it back together. I am assuming there was corrosion on the plugs that was interfering with the signal.
