Hurst shifter problem need help
Old Apr 15, 2024 | 09:05 PM
dtrctd13's Avatar
dtrctd13
So I’ve been cleaning up the linkage on my 3 speed and know how to align everything now. I was coming across a problem today because the bolt on the side of the shifter that should keep it in place moves forward mainly when shifting into reverse. The other gears it doesn’t move as much but I’m assuming maybe it needs a lock washer instead if whatever this is in the picture? Anything will help thank you!
Old Apr 15, 2024 | 09:14 PM
tbear853's Avatar
tbear853
If it "moves forward" is it because the shifter is broke? If you mean that it "rotates" like it's going to loosen up, just use two nuts locking together.
Old Apr 16, 2024 | 02:59 AM
dtrctd13's Avatar
dtrctd13
Shifter
yea I assumed that but should I take one of those lock washers and put it on the inside of one of those screws and take the other off? There’s two of those screws on the one side? But yes it’s not broke it just rotates forward but I did tighten what’s on there and it still moves
Old Apr 16, 2024 | 08:12 AM
uzikaduzi's Avatar
uzikaduzi
not sure i understand your question, but lock washers belong against the nut side of the bolt; however, if you have 2 nuts (one working as a lock nut) i don't see any reason to use 2 methods to prevent the nut from backing off.
Old Apr 16, 2024 | 08:24 AM
dtrctd13's Avatar
dtrctd13
sorry the shifter is moving forward with the gears instead of staying still especially bad going into reverse(it’s a 3 speed) seems this setup is not strong would split lock washer and a bolt hold it better?
Old Apr 16, 2024 | 11:01 AM
uzikaduzi's Avatar
uzikaduzi
ahhh i understand. i'm not an expert on this type of thing, but i don't think either would be very different from the other. might be a red Loctite scenario?
Old Apr 16, 2024 | 01:17 PM
redroad's Avatar
redroad
It's better you don't start more thread on this topic. It keeps the info gathered and possible solution in the same place should someone else need to find it.
In this thread did you try the link I posted. Did you find the library of Hurst shifters. There are diagrams and installation instructions there.
Old Apr 16, 2024 | 02:27 PM
dtrctd13's Avatar
dtrctd13
Hurst shifter
I did it seemed pretty difficult to navigate through the website. Alright I didn’t want to but was hoping may get more insight
Old Apr 16, 2024 | 02:29 PM
dtrctd13's Avatar
dtrctd13
Hurst shifter
So I ended up getting a washer, split lock and a new bolt. It is staying way tighter now but for some reason when the truck is on it makes me push into reverse more and in turn that shift body moves slightly. Would loctite easily do the trick
wizzy214
30
Jul 9, 2022 04:23 PM
armyaviation
Jun 7, 2022 04:32 PM
Tristanrf
1983 - 2012 Ranger & B-Series
Mar 28, 2019 07:42 PM
northeasthighboy
Feb 4, 2011 12:18 PM
chrissmallwood
Jun 30, 2010 01:07 AM
