Help Fuel Pump/sending unit
Old Apr 15, 2024 | 09:18 AM
1992 Ford Flareside's Avatar
1992 Ford Flareside
4wd Low
Can you change out just the fuel pump part. I am wanting to keep the factory plug on the fuel pump assembly. The fuel pump/sending unit that we have has a bad float and fuel pump. I've tried finding videos on how to do so but I am not having any luck. We can get the bottom part of the white plastic part off but can't get the stainless-steel tubes out of the top part of the plastic.
Old Apr 15, 2024 | 09:22 AM
subford's Avatar
subford
You use the wedge that comes with replacement pump.
Old Apr 15, 2024 | 09:30 AM
1992 Ford Flareside
4wd Low
So something comes with the new pump that allows you to change it and has the oem equipment?
Old Apr 15, 2024 | 09:56 AM
subford's Avatar
subford
Yes the dose.
Old Apr 15, 2024 | 04:40 PM
Conanski's Avatar
Conanski
The hard lines will disconnect from the plastic pump body, there is a screw or 2 that has to be removed first then the lines can be shimmied out by pressing down on the metal collars(red arrow) while pulling up on the lines. You have to work each line a bit at a time to get it apart.
The plastic resovoir will also come apart but it isn't really meant to, you may damage it a bit i the process, but with some patience it can be done.
4EyedTurd
Feb 23, 2023 07:49 AM
JJF20
Apr 13, 2019 08:53 AM
4dfan
Escape & Escape Hybrid
Jun 10, 2011 01:50 PM
kennyrandolph
Mar 17, 2009 06:49 PM
MustangGT221
Aug 10, 2006 09:22 AM
