fuel pump problems
Old Mar 14, 2009 | 09:09 PM
kennyrandolph's Avatar
kennyrandolph
fuel pump problems
i have a 1993 f150 xl. my rear pump works but the sending unit dont not. my front tank pump does not work but the sending unit does. cound the enercia swith cause just one pump to not work?
Old Mar 15, 2009 | 10:27 AM
twelvepaws's Avatar
twelvepaws
In each tank there is a low pressure pump that feeds your high pressure pump on the frame rail. Each low pressure pump needs to working in order to feed the Hi pressure one.
Old Mar 15, 2009 | 11:19 AM
88n94's Avatar
88n94
Not on a 1993. Starting in 1990 they just put a high pressure pump in each tank and eliminated the frame rail pump.
Old Mar 16, 2009 | 07:57 PM
twelvepaws's Avatar
twelvepaws
miss informed
My fault! I did'nt know they changed that setup. I appreciate your update.
I've been dealing with my old 1988 4x4. i just went through all that pump business only to find out I have no impulse at my injectors. I'm curious to know if this means I have to replace my whole computer in this truck or is it just to much of a hassle. It's just way to much truck to just scrap out. It does'nt even have 100k on it yet.
Old Mar 17, 2009 | 12:31 AM
88n94's Avatar
88n94
I assume you have checked to see that you are getting spark through the spark plug wires, or gave it a shot of starting fluid to confirm that you have ignition? If the ignition module on the side of the distributor goes bad you will have no ignition, also the injectors won't pulse.
Old Mar 17, 2009 | 06:49 PM
twelvepaws's Avatar
twelvepaws
1988 f150 4x4 DOA
Yes, I had it running once by pouring a little fuel into the breather ports. It ran good until the fuel ran out. My helper told me I had real hot spark that day. It sounds like I'll have to replace the computer. I don't have a clue as to how much that can cost these days.
