Transfer case question
Old Apr 14, 2024 | 06:53 PM
yeet's Avatar
yeet
Hi Guys,
In the near future I need to replace the output shaft seals on my transfer case. Both are slowly leaking. I looked in my Haynes manual today and saw three different transfer cases mentioned. My truck is a 95 F150, 4R70W trans 302 motor XL model. What transfer case would it be?
Haynes mentions a New process 2 speed part time, A Warner 13-45 full time, and a Borg Warner 13-56.
It has the manually shifted case on the floor.
Any help?
Old Apr 14, 2024 | 07:57 PM
Sparky04SD's Avatar
Sparky04SD
There should be a metal tag riveted to the back side of the transfer case with model number on it.
Old Apr 15, 2024 | 04:05 AM
manicmechanic007's Avatar
manicmechanic007
It should have a 13-56 in it
Old Apr 15, 2024 | 04:36 AM
arse_sidewards's Avatar
arse_sidewards
Read this:
https://www.blueovaltrucks.com/tech-...ransfer-cases/
You "should" have the 1356 but if you don't it should be pretty easy to figure out
Old Apr 15, 2024 | 05:29 AM
My4Fordtrucks's Avatar
My4Fordtrucks
That would have been my guess based off what is in my three trucks. The NP transfer case is definitely not there. I thought the BW 1345 was a part time transfer case.
As stated in post 2, slide under the truck to see what is on the tag.
Old Apr 15, 2024 | 09:25 AM
yeet's Avatar
yeet
Thank you to all. I'll have to clean all the grime off and look at the Tcase next time I'm under there.
Woods hunter
Dec 6, 2023 05:40 PM
Grey89F250
Apr 16, 2008 10:31 PM
gui88ford
Sep 23, 2001 08:54 PM
