1966 - 1977 Early Broncos
351w intake manifold
Old Nov 25, 2003 | 06:25 PM
ROKRAWL's Avatar
ROKRAWL
Looking through my haynes manual i noticed on the v8 diagram that a "seal" is installed over top the manifold gasket set for 351's only. I have a 351w but did not get the "seal: with the gasket kit. My gasket kit does have 4 pieces though and the diagram shows a two piece. Is the "seal" necessary? Is my gasket set sufficient? Thanks in advance.
Old Nov 26, 2003 | 11:10 AM
spartamouse1's Avatar
spartamouse1
there are 4 pieces to the gasket set. two long side rail gaskets and the short end rail gaskets. sounds like you have the right kit. they lock together in the corners to prevent slipping when bolting down.
Old Nov 26, 2003 | 11:16 AM
stepman's Avatar
stepman
I don't know of any "seal" on that but I do put "seal ER" in the corners where the gaskets meet. Only thing I have seen would be the little round plastic things that go in the bolt holes but those are just to help the side gaskets stay put. ( I thought)
Old Nov 27, 2003 | 01:25 PM
RCrawler's Avatar
RCrawler
The only seals I can think of are the rubbers that go on each end.
In my experience, I've always thrown them away and used a bead of silicone to seal the ends. The rubber seals tend to spit out when you tighten the intake.
Jason
bigblack302
Mar 16, 2009 03:36 AM
adharvey2
Oct 1, 2007 11:26 AM
red75bronco
Mar 3, 2004 12:16 PM
charleslincoln
Sep 5, 2002 01:02 AM
Superdave
Feb 27, 2002 06:09 PM
