Rams horn manifold gaskets
Old Sep 29, 2007 | 11:05 AM
adharvey2's Avatar
adharvey2
I had to replace a blown head gasket on my C600 292 and am trying to find the original type exh. manifold gaskets with all of the heat shielding. Every gasket set I can find lists exh. man. gaskets "w/o heat shield". Even Felpro doesn't have them. Any suggestions on where to look? Would a Ford P/N help?
I could reuse the old ones. They're just tin and come off easily in one piece.
Or should I just skip the heat shielding and use the ones that came with the set that are just the regular thick, foil covered type that just go around the ports.
If I reuse the original ones, what are the potential consequences of a poor seal?
Andrew
Old Sep 29, 2007 | 09:59 PM
Y-Blockhead's Avatar
Y-Blockhead
Andrew,
Check this post on Y-Blocksforever.com http://www.y-blocksforever.com/forum...anifold+gasket
I think these are what you are lookin for??
Y-Blockhead
Old Sep 30, 2007 | 10:56 AM
adharvey2's Avatar
adharvey2
Guess I just didn't look hard enough. Thanks Y-Blockhead!
Old Oct 1, 2007 | 11:26 AM
312's Avatar
312
most dont use any.
norts1138
Aug 28, 2014 12:21 PM
Wild Weasel
Sep 27, 2011 12:37 PM
ford66
Aug 17, 2009 08:09 PM
buckrogers
Dec 5, 2008 11:36 AM
gregg_a_g
Feb 26, 2007 05:45 PM
