Sponsored by: Real Truck
No 4x4!!!
Old Apr 21, 2024 | 05:24 PM
Kalvis111's Avatar
Kalvis111
7th Gear
Well I figured it out and wanted to post it on here for someone in the future. It was the wire that goes from the 111 fuse to the back of the relay. Dark green with light green stripe. It’s a single wire that splits into 4 about 5 inches before the 4x4 relay. Somewhere between the back of the fuse panel and the firewall it must have had a break. Instead of taking apart all the perfect wire looms to find it, I just utilized one of the 4 factory accessory wires that go form under the dash to the outside engine compartment to bypass it. I tapped into the green/light green wire behind the fuse panel to get my power and then Retapped into the same wire right before it split into 4. Problem solved, 4x4 works exactly like it should.
Old Dec 17, 2024 | 12:10 PM
Ray191713's Avatar
Ray191713
6th Gear
the relay block thats under the hood, the wire boot has three connectors. how many of these connectors should have power. My relay only has power on the center connectors . Is this correct
Old Dec 17, 2024 | 06:30 PM
Model a ford's Avatar
Model a ford
On my 03 f350 7.3 auto 4x4, switch on dash ( SOF) didnt have any lite and would not go into 4x4, I found there was no ground on relays ( believe ground is controled by powertrain ecm) I found if I shut engine off, turned SOF switch on dash into 4x4 high, then start, it would shift. Then to get it to come out, I had to momentarily grd the relay ( cant remember which one, but think it was back one) for no more than 3 sec. I put a momentary switch on dash. Not proper, but works. I tried a used PTECM, it didnt work either, so then didnt know if it was faulty also, and new one was $400. Hence switch on dash!!
elkkiller34
Jul 18, 2017 01:41 AM
jsavin
Jan 2, 2013 07:06 AM
bobwhyte2002
1983 - 2012 Ranger & B-Series
Feb 22, 2009 10:11 PM
kc2006
Oct 20, 2008 07:08 PM
