Aluminum/Stainless
Old May 4, 2024 | 04:18 PM
RabbiBob's Avatar
RabbiBob
7th Gear
Welcome to FTE.
Good advice given here. You’ll see in my write-up that I use a common brass 3/8” compression and aluminum tubing with a 90* bend at the bottom so it can suck from the very bottom of the tank. I also do not put any stock in the crazy notion that the factory quick-connect fittings leak. The 30R9 or equal fuel hose required to replace the factory lines is expensive and far more prone to failure than the stock tubing. The WIX 33972 is plenty adequate to replace the pre-pump filters we removed. Even with inflation, this upgrade should be about $30.
However, my concern is that this may not be the fix for your no-start situation. WHEN the pickup foot/umbrella fails, the truck will run out of fuel about 1/4 tank. Adding 5gals or so of fuel to the tank would solve the no-start if this (broken umbrella) is the problem.
Another way to check fuel supply to engine is by using the water drain valve on fuel filter. I like to add a section of cheap vinyl 5/16” ID tubing to the drain line. It dumps about 1/2 way down the front passenger side of the engine, near the water pump. Just slide the vinyl hose over the steel line and make it long enough to reach a container (1/2gal or bigger) on the ground. Now, open water drain valve on filter housing and collect/inspect the contents from filter bowl. With the valve still open, turn the ignition to ON, but do not try to start the engine. The fuel pump will run about 20sec and you should get about 1qrt of fuel. The flow should be steady and not aerated. Like an old school water fountain.
If the flow is good, then ‘fuel’ is not your problem. Close the water drain valve and cycle the key ON for 30secs 3 times before trying to start the engine again.
Meanwhile, do the Service Engine Soon and Wait to Start lights come on and go off when you turn the ignition ON?
Thanks for the reply. I got the suction/filter mod complete. Took awhile but ended up being easier than when I started. The fuel pressure was at only 30psi. Put in a new fuel pump and added the pre filter. My fuel pressure is now 50/60psi starts fine then dies just idling and also under pull sometimes. Thinking maybe the post filter on top of engine might have collected some junk idk but it just isn't right yet. I'll continue to check things out and maybe post what it is doing. Thanks for the reply and mentioning another possible problem. I like the fix.
flynbya2
Apr 28, 2024 10:12 AM
DragonMDB
Jan 15, 2013 10:07 AM
misterfisher
Oct 10, 2010 05:02 PM
joe doyle
Oct 28, 2009 10:49 PM
