Throttle Position Sensor
Old Apr 11, 2024 | 05:13 PM
Olds69442's Avatar
Olds69442
Anyone have to change the accelerator pedal. I get the P2074 code, changed the MAF, and MAP sensors. Accelerator pedal is last part left.
Old Apr 11, 2024 | 10:04 PM
Trash Hauler's Avatar
Trash Hauler
There is a lot more to the P2074 than two sensors and the pedal. Have you checked for leaks in the CAC system, particularly the cold side CAC tube? You might actually have a problem and not a bad sensor (especially since you have changed the MAF and MAP).
I have an intermittent P2074 on my 2013 but I have a pretty good idea of the culprit. I replaced the cold side cac tube and afterwards, the intermittent code started appearing. The temp sensor in the cac tube does not feel tight, I even replaced it to eliminate a bad o-ring. No luck so I am going to put the original cac tube back on and see if the problem goes away.
I am trying to find the code in my shop manual but for the life of me, I can’t find it. If I do, I’ll post the troubleshooting steps for you.
There is also a TSB for the 2011 and 2012 that you may want to read.
TSB 22-2115
Bob
Old Apr 12, 2024 | 05:22 AM
Olds69442's Avatar
Olds69442
Thanks for the info. Much appreciated.
AGrayson84
Nov 8, 2016 02:56 PM
nickt916
15
Nov 30, 2013 05:15 AM
tfdcapt
Sep 16, 2013 11:38 PM
Franko72
Apr 27, 2011 09:36 PM
95STROKER29
Feb 25, 2008 10:43 PM
