9" disc conversion contacting dims
Old Apr 10, 2024 | 10:08 AM
NIXDSG's Avatar
NIXDSG
I did a 9" disc brake conversion, now my calipers are contacting my rims. Options?
I installed an 1/8" spacer, no luck. Would need 1/2", then maybe. Don't like this option for many reasons.
Old Apr 10, 2024 | 10:11 AM
NIXDSG's Avatar
NIXDSG
Oh, in that picture I cut the pin shorter, I think it clears but still contacting the caliper.
Old Apr 10, 2024 | 11:25 AM
52 Merc's Avatar
52 Merc
There's plenty of meat on the caliper in that area and it's not uncommon for guys to make minor grinding modifications to gain the needed clearance. It looks like it's just barely touching. It shouldn't take much massaging to work. It's either that or try different, newer rims.
Old Apr 11, 2024 | 08:26 AM
NIXDSG's Avatar
NIXDSG
Well I got it without gringing the caliper. I trimmed the pins a 1/2" then adjusted the e-brake, which moved the caliper inboard. Still contacted but just slightly. Added the 1/8" wheel spacers and it's good. I assume after the pads set or wear a little ill be able to remove the wheel spacers.
My goal is to keep the original steel wheels, that old school ratty look with that little bit of rust.
Moonlightford
Dec 22, 2023 09:13 PM
818rider
Sep 20, 2022 09:52 AM
jonjenni
Nov 28, 2020 10:01 PM
BGF100
Feb 26, 2017 09:52 AM
RicManSr
Jul 8, 2009 09:34 AM
