Transmission delay going from 3rd to 4th
Old Jan 27, 2025 | 11:00 PM
Cscott925's Avatar
Cscott925
2nd Gear
2024 PSD HO same issue shifting from 3rd to 4th
I’m having the same issue with my 2024 PSD with 3500 miles on it. Doesn’t matter cold or warmed up it does it pretty consistently under light acceleration. Not sure if it’s worth my time taking to the dealership or if they could even do anything about it but it is annoying.
Old Jan 28, 2025 | 06:50 AM
The Seeker's Avatar
The Seeker
i read this on FB 2 to 3 weeks ago, put the truck in neutral for 30 seconds before leaving, when i get in my truck i put it in neutral (truck has been idling for about 10 to 15 min.), set the e brake, get my seat belt on screw around for 30 seconds, for me it has completely eliminated the 3 to 4 gear surge or lunge
Old Feb 3, 2025 | 07:10 PM
SandR's Avatar
SandR
Add mine to the list. 2017 f350 drw with 56k miles hesitating when going from 3-4. I did the PCM recall last week and really noticed the delay after that. I went back to dealer and we rode around. It got a little better and at times when not heavy on the pedal the shift is normal. The dealer said drive it and see if the relearn will help. The problem is when towing you cannot be light footed. Does anybody know of the fix? My ESP runs out the end of this month. I did read about a TSB above so will research a little.
Thanks
Old Jun 12, 2025 | 06:35 AM
James144's Avatar
James144
1st Gear
Originally Posted by andrew8406
I have the '24 HO PSD and it does it from time to time. Not often. Generally under very light acceleration. Hard acceleration has never caused it, that I've experienced. Only 4k on the truck so far. Just wanted to throw some more data out there, since nobody has mentioned it happens on their power strokes. I should also mention that I have mostly experienced it on the 3-4 shift, but I believe it's happened on other low shifts, like 4-5 as well. I've just been chalking it up to the transmission learning so far. It is pretty occasional for me.
I have a 24 HO PSD as well. Same issue, under light acceleration around 30 MPH, doesn't shift to 4th.
Old Jun 12, 2025 | 06:45 AM
HorizontalHunter's Avatar
HorizontalHunter
Originally Posted by WXboy
There are a hundred of these transmission threads, and 95% of the time the owner has no idea if the transmission service has ever been done. Start there.
If a fresh filter and fluid doesn't resolve it, then go to post #4 in this thread because the 2017s did have some trucks with valve body issues. I think there was a TSB for it.
This.
My 22 (13k miles) will does all kinds of weird stuff; flare shift 1-3, and especially 3-5, sometimes it is a hard shift. The dealer says nothing is wrong.😵‍💫 I am going to try to clear the adaptive learning tables thru forscan and see if that helps.
Bob
Old Jun 12, 2025 | 06:48 AM
HorizontalHunter
I have found driving with a little more pedal authority definitely helps mine.
Bob
Old Jun 12, 2025 | 01:41 PM
cpobst's Avatar
cpobst
Mine also had the annoying 3-4 shift delay when cold. A transmission tune solved this and all the other annoyances it had.
Old Jun 12, 2025 | 09:54 PM
BigBlue22's Avatar
BigBlue22
More info on what tune you have please. Been looking into 5 star this might make me pull the trigger.
Old Jun 12, 2025 | 09:56 PM
cpobst's Avatar
cpobst
I used ASAP Calibrations. 5 star seems to be a great place also. But I really think these issues are in the tuning, nothing else.
https://asapcalibrations.shop/produc...mission-tuning
Old Jun 12, 2025 | 10:17 PM
BigBlue22's Avatar
BigBlue22
Thanks for the link, yeah agree on the tuning. Now I just decide to do it now or wait for power train warranty to run out. I’ll probably wait, but I saved the website.
Old Jun 13, 2025 | 12:56 AM
bent-1's Avatar
bent-1
Might want to look at the valve body
Whitey5.0
Sep 14, 2017 04:29 PM
jgavac
Jan 24, 2013 10:50 PM
6LPSD
Nov 14, 2009 05:26 PM
SCscrew
2009 - 2014 F150
Aug 28, 2009 03:20 PM
eev
1983 - 2012 Ranger & B-Series
35
Oct 10, 2003 03:31 PM
