Front Air Dam
I ordered the 2 WD 4” version, as I didn't want it to short.
I’ll follow up after install.
interested to see how it fits etc.
post back once it’s on
Bro what are you on?
I’ve had the 2wd valance on my 21 super duty. It’s not a debate of what the thing looks like plus you can google what it looks like. Not too hard to do n
I was just asking (due to this guy who posted his being an aftermarket brand and not OEM) if the fit and finish was good.
the 2wd looks just fine in my opinion. Sometimes I think the tremor valance is too minimalist and makes the trucks look like they have a bit of an overbite lol
What was disappointing? 2WD valence too short? Too long?
And if you're referring to the "Prius Catcher" brackets as unsightly, yeah, everyone removes those. At least that's what I've seen on the internet!
The brackets are for collision compatibility with the bumpers and crash energy absorption strategies of smaller vehicles (not just Prii)... not shipping tie downs, and not to keep the valance from blowing back, as others have theorized.
To pre-empt the feds from formulating rigid regulations that would constrict design and constrain manufacturers from the flexibility needed to innovate, members of a consortium of automobile manufacturers agreed to VOLUNTARILY produce trucks and suvs with collision compatibility considerations for smaller vehicles.
Ford led the way in this effort, since Ford's cash cows are all grazing in the market fields of large trucks and suvs.
Certain 2 wheel drive trucks are already low enough to the ground at the front bumper, where no additional measure is necessary to be collision compatible with smaller vehicles.
Certain chassis cab trucks are over the GVWR threshold that is most subject to regulation, so those vehicles may not have brackets (none of the F-550's I've ordered have them).
The payoff for Ford in getting ahead of the safety concern for smaller cars versus larger SUVs and pickups that was brewing in the minds of FMVSS regulators in the '90s... is found in the Tremor, where the flexibility to produce a recreational / off-road model that has a higher approach angle is afforded by the fact that collision compatibility compliance is still voluntary, and not mandatory for every single model of vehicle.
As long as most of the manufacturer's vehicles are collision compatible, bureaucratic efforts to codify such regulations are kept at bay.
The original Super Duties and Excursions at the turn of the century had a much more expensive to produce Blocker Beam, which was in fact "bigger and beefier", but is not necessary with the newer designed Super Duty frames from 2008 to 2016, and 2017 to present, due to the lowering of the main frame horns, made possible by hydroforming a deeper drop down ahead of the front axle, unlike the forward frame formation of early 1999 - 2007 main rails, which did not dip down as much ahead of the axle.
The foregoing comments are in response to:
Thank you for the very informative and highly enlightening explanation and for clearing this up. It all makes sense.
However, despite this info, when I install the 4" 2WD valance, I will probably still remove the 2 brackets that hang down even though I am fully aware of the safety factor I am removing. That is unless they (IMHO) don't look to bad or hang to low beyond the bottom edge of the valance.
Thanks again for the detailed info.
Now I'm a little PO'ed that I got incorrect information from a complete stranger on the internet. What is this world coming too!
2- where in NY are you located?
? Are these only on newer model super duty’s ?
