Modern 79 build
Old Feb 10, 2025 | 08:33 PM
  #46
Papa’s79's Avatar
Papa’s79
Originally Posted by red75bronco
Ford now makes a 10r80 controller. I was more interested to know if you ever mounted the 10r80 to the Godzilla. I think the 10r80 has a 2 bolt starter.
I never actually mated mine together. I have a brand new 10R80 I was going to use but at the time Mars was the only one I knew making a 7.3L/10R80 so combo I never used it.
Knowing there is now a stand alone controller will definitely help the sale of my 10R80 I need to get rid of now.
If you need any measurements or pictures of the 10R80, let me know.
Old Feb 10, 2025 | 08:43 PM
  #47
red75bronco's Avatar
red75bronco
I have one coming, mine is a 4x4. Could you take a pic of the starter Mount?
Old Feb 21, 2025 | 04:20 PM
  #48
Papa’s79's Avatar
Papa’s79
Today I had what I consider a huge win! I put the chassis on my alignment rack to check primarily thrust angle since cutting the frame and adding all the suspension to find out it is 0.00° which is just absolutely amazing. A lot of prep and measurements went into making sure it was as close as possible, but I never would’ve dreamed of it being as close.
Old Feb 21, 2025 | 06:01 PM
  #49
1TonBasecamp's Avatar
1TonBasecamp
The thrust angle is great!
Uh, but the toe angle at one end on that screen is a little out of whack! :-)
Just kidding. Nice job overall. Not surprising you nailed it.
Old Feb 21, 2025 | 10:24 PM
  #50
Papa’s79's Avatar
Papa’s79
Thank you. All other alignment points are easily addressed with the OEM systems (Mustang rear and Crown Vic front) however the thrust angle is an overlooked point on a lot of full chassis builds. I was looking that the chassis was square and just correct. The nervousness my OCD had on it being straight was crazy.
Old Aug 13, 2025 | 12:18 AM
  #51
Papa’s79's Avatar
Papa’s79
Finally got some more time to spend on my project and got a few big steps forward. Finished up a full 3” stainless exhaust using Magnaflow mufflers, flex couplings, and all held together with v-band clamps for easy removal (and looks haha). Decided to try my hand at making an x-pipe for the first time as well and very happy I was able to have to room to do so. Since the driveshaft will be “fixed” by using IRS, there is no travel issues of it ever hitting. I snuck the exhaust under the rear subframe as OEM does on the Mustang to also help with ground clearance.
Also finished the full fuel system using -3AN fittings and PTFE line in case I decided to tune it for ethanol in the future. Sure would be a nice way to get this engine into the 700HP+ range
Driveshaft was also made by a local shop using a MASSIVE 1480 u-joint on the 10R140 side and a 1410 on the Mustang IRS 8,8
I did start it up and was wildly pleased with the sound, a perfect rumble at cold start and then it quiets down to where you can really hear the BTR cam thumping!!
Next up is brake line plumbing and cooling system
Old Aug 13, 2025 | 06:31 AM
  #52
Kman-S.E.USA's Avatar
Kman-S.E.USA
Words aren't enough to describe the depth of this build. Amazing work and I can't wait to see the video of it running down the street!!!
Old Aug 13, 2025 | 07:23 AM
  #53
red75bronco
Who did you get your SS exhaust pipe from?
Old Aug 13, 2025 | 08:08 AM
  #54
Papa’s79's Avatar
Papa’s79
Thank you!. I’m closer than I keep thinking I am or at least keep telling myself that to keep optimistic. Haha. I’m very excited too.
JPuck81
Oct 29, 2024 12:27 PM
ThatGuyFromGates
32
Jan 13, 2018 11:07 PM
AAM
Projects
15
Oct 9, 2010 06:02 PM
no1lowr
Oct 12, 2009 09:37 AM
clutter
Oct 10, 2008 08:01 AM
