2001 fuel system
Old Apr 9, 2024 | 02:26 AM
OldMechanic57's Avatar
OldMechanic57
Originally Posted by udsuth78
That is actually a high pressure needle valve. They are often used for flow control because of the fine adjustment they provide. I like using them as throttle valves on natural gas oilfield engines in situations where there just isn't a lot of fuel gas available. I can fine tune the mix to run a little on the lean side to conserve fuel. Also good for slowing an engine that's really just to damn big for the job. I can set the governor to hold the butterfly closed, then use the idle screw to just crack it open a hair. The needle valve lets me bring the fuel flow much lower than a ball valve ever would but still have the option of opening her up when needed. So technically it is capable of kinda working as a regulator, but still janky AF and several better easier and simpler ways to to do the job. Did this used to be a farm truck? I see farmer engineering written all over this setup.
Are you sure you didn't do this mod for the OP?
Old Apr 9, 2024 | 03:03 AM
udsuth78's Avatar
udsuth78
I only do that kind of stuff on old single cylinder oilfield iron when the operators don't want to spend the money to do it right. They think it's cheaper to continue paying me to "just get it running". All I can do is tell them what needs to be done, it's their motor and their money. I'll tell him the risks but if the man says just make it run I'll make it run. I can make most anything ru, provided it's still in the correct number of pieces. Not much I can do when a piston decides it wants to focus on it's solo career and doesn't need things like connecting rods or crankshafts holding it back.
Old Apr 10, 2024 | 07:43 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
On the plus side she's rocking a new ICP.
Old Apr 11, 2024 | 08:52 PM
Hellraiser456's Avatar
Hellraiser456
I would hit up a pick n pull and scavenge as many stock parts as i could, and replace everything. Buy whatever i couldn't find.
Get new gaskets of course. They way those fuel lines are bent without support, i would be worried about their integrity.
​​​​​THat looks like a fire hazard.
Old Apr 11, 2024 | 10:51 PM
Wes444's Avatar
Wes444
Yep ^^^
We use em at work on bearing lube flow to dial in the flow rates @ manufacturer specs so it doesn't blow the seals out.
Typical bearing. That's a 3" wide strap, and a 40"x48" pallet.
Was a premature failure at only 12 years due to failed flow meter
Old Apr 12, 2024 | 06:57 AM
Tpayne621's Avatar
Tpayne621
So basically a fancy more precise ball valve. lol that will not regulate pressure just flow.
Old Apr 12, 2024 | 07:56 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
So whos gonna start fabbing and selling needle valve fuel systems?
Old Apr 12, 2024 | 10:29 AM
udsuth78's Avatar
udsuth78
What do y'all think the Riff Raff frx kit is? It just takes away the adjustability by using an orifice instead of a valve. Granted it retains the fuel bowl, but that's really only a fuel filter housing at that point.
Old Apr 12, 2024 | 10:41 AM
Tpayne621's Avatar
Tpayne621
The frx still uses a factory regulator to actually control the fuel pressure though. Slightly different then setup this post is about. lol
Old Apr 12, 2024 | 04:20 PM
OldMechanic57
This is my setup. Delete the bowl of course. Tig welded an L bracket out of 1/2” 6061 aluminum with bosses to stand off of the mounting point of the fuel bowl. Tapped the bosses and the top to accept my fuel distribution block. All distribution hoses to the 4 corners of the heads are RiffRaff which all are “uphill” to the block since air will rise up. This brings us to the needle valve with the orange hose that goes back to the return line since I am not using the OEM method of fuel delivery any longer. The valve is used to purge air back to the tank in case I need to bleed the air off. I have a FASS system which delivers the fuel via the large blue hose, so I have fuel pressure regulation back at the FASS system. No more air through the injectors for me. Works very well as the FASS pump runs all the time the ignition is on. I can open and close the valve and the air rises and is forced out. The sensor goes to my EDGE display showing my fuel pressure at all times the engine ignition is on.
Old Apr 12, 2024 | 04:35 PM
ESwift's Avatar
ESwift
CNCFAB
I vote Airdog 5g and a 4 line feed. Clean, functional, reliable.
Old Apr 12, 2024 | 04:53 PM
OldMechanic57
That does look nice and also frees up some space. I almost went that route also, even talked to the guy at C&C Fab, I just saw air entrapment which prodded me to go the route that I chose since we both still have dead head fuel systems.
Old Apr 12, 2024 | 04:57 PM
  #28
ESwift's Avatar
ESwift
CNCFAB
When did ya call, maybe you talked to me😉
I havent had any air issues on this or my other truck. Can definitely understand your train of thought.
I’m all for diy, yours is especially clean and well put together compared to most that I have seen
Old Apr 12, 2024 | 07:03 PM
  #29
OldMechanic57
Probably about 7-8 months ago. I truly like your design, it is very clean, much more appealing than my approach. In fact, your design was the only other approach that I considered before designing my own. I may just be too **** about air, but I honestly like being self sufficient when I know that I can achieve a solution to a task that presents itself. It is nice getting to know you guys and converse on this forum with you.
FordTruckNoob
31
Nov 28, 2021 09:42 PM
6.9IDIot
27
Apr 25, 2020 02:37 PM
twopeas6572
Oct 16, 2019 08:28 AM
brandon_oma#692
Feb 28, 2018 08:00 PM
Robbieo11
Jun 20, 2014 09:20 PM
