Chip tuner stopped mid program
Old Apr 7, 2024 | 07:53 PM
inlinescott's Avatar
inlinescott
Trailering
01 F350 7.3 diesel. Was changing back to stock with my edge tuner. The controller went blank midway thru programming bank 2 of 4. I unplugged and plugged back in. Now won't tune and get error message. Truck won't start (cranks but no fuel pump). Emailed edge but it is the weekend. Just trying to make sure if any other options besides a tow to stealership if that is where I land with edge. How much does a flash to original cost.
Old Apr 7, 2024 | 09:21 PM
Tpayne621's Avatar
Tpayne621
Does that chip hook into the pcm like most or does it jsut use obd2? I've never messed with a edge one before. But if it's goes into the pcm try unplugging it from pcm and see what the truck does with it unhooked.
Old Apr 7, 2024 | 10:07 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Call Edge tomorrow. They'll get you up and running by forcing a stock tune back into your PCM with little issue and it'll likely be without cost. Your PCM is "bricked" right now. Nothing but another PCM will make it run before then. Be patient and call them tomorrow.
Old Apr 8, 2024 | 08:16 AM
inlinescott
Trailering
plugs into OBD2. I only connect when I change from stock to tow. Was installed when I bought the truck and I'm not savy enough for custom tuning. Truck does not start connected or not. Waiting for 8am mountain time to call edge. Thanks for the replies. I will follow up after I talk to them.
Old Apr 8, 2024 | 12:25 PM
RacinJasonWV's Avatar
RacinJasonWV
This.
My uncle had something similar happen on his ecoboost. I talked with Edge and she got us squared away with some sort of force tune. Don’t remember the details but Cleatus is the expert so I trust he’s 100% correct. It wasn’t a short call though. Took a while but they took care of him.
Seems like the recommendation was to always have the truck on a battery charger while programming. Low voltage can cause program failure IIRC.
Old Apr 11, 2024 | 01:37 PM
inlinescott
Trailering
Follow up
Called edge 4/8 in am. Had to overnight both tuner and pcm to them at their expense. Due to misunderstanding they did not receive pcm until Wed 4/10. Edge set my pcm back to stock. Tuner was not repairable (possibly age). It was returned to me before lunch today 4/11 (less than 24 hrs later). Installed pcm and truck is back and chuckling. Impressed with customer service. Still gun shy about a tuner that wipes and writes the pcm. Edge offered an "inline" chip at a discount and I said I'll think about it. Thanks for the the calming word cleatus.
Old Apr 11, 2024 | 07:04 PM
Tpayne621's Avatar
Tpayne621
Sounds like a good time to upgrade to the php hydra. It is the go to unit now days.
Old Apr 11, 2024 | 07:08 PM
John in OkieLand's Avatar
John in OkieLand
This.
THIS......
you absolutely, must never have a Power Surge, or loss of power while Programming any computer, period...
you can brick a Windows PC that way.
on those, reformat the disk, and reinstall.
Edge can do the same for you
Old Apr 11, 2024 | 07:10 PM
John in OkieLand
yep,
got the Hydra tuner,
love it.
it allows you to change the tune while driving....
BUT, there is a Caveat to that, better not pass through the 1,000 RPM setting.
Old Apr 11, 2024 | 08:27 PM
Tpayne621's Avatar
Tpayne621
If you jsut pass over them without pausing it won't ever be a issue. It skips over them until you stop on one for a couple seconds and it flashes. Then it switches to that tune position.
tony2toes
Oct 23, 2014 05:32 AM
DIYMechanic
58
Nov 23, 2013 11:28 AM
ech0sh4y
Nov 9, 2013 10:45 PM
ech0sh4y
Nov 8, 2013 09:43 PM
powerstrokeddiesel
25
Feb 27, 2008 09:27 AM
