Boost Auto mirrors installed
Old Apr 5, 2024 | 05:03 PM
Jay870's Avatar
Jay870
Made an expensive mistake. Was backing up my driveway and slapped my passenger side mirror against a tree and mangled it all to hell. My excuses are as follows: 1) My driveway is very long, curvy, lined by trees and somewhat narrow in spots. 2) Visibility was poor as it was raining and at dusk. Reality is I was mentally distracted, going too fast and complacent from backing down this driveway a thousand times over the last dozen years. Once I got done with berating myself I realized that I was very lucky that the only damage was the mirror, I wasn’t far from dragging the side of the truck down the tree.
OEM replacement for this mirror is $900+(!). That is just for an XL mirror that has manual fold & manual extend with heat, power adjustment, and side lights. If your truck has power fold, power extend, BLIS, camera, spot light and puddle lights then god help you. New OEM was off table. Salvage off ebay looked to be $500-ish.
Looked around a little and ended up ordering a a set of Boost Auto tow mirrors. These seem to have overall good reviews and the company seems responsive to issues. These have a ton of options depending on your as-built mirrors including the ability to add power fold and power extend to a truck that didn’t have it. I stuck with a pretty near as-built config for my truck and paid a small premium for the smoked lens, the amber sequential signal with running light, and heated lower mirror. $720 shipped for the pair.
Ordered Sunday, arrived Thursday. Very well packed in a heavy corrugated outer box, heavy corrugatged inner boxes for each mirror, and well padded with foam and air bags.
Initial build quality impression is excellent. Material thickness, weight and finish of the housing is effectivley indistinguishable from OEM. The mirrors are clear, smooth and defect free.
Old Apr 5, 2024 | 05:04 PM
Jay870's Avatar
Jay870
Installation is surprisingly easy.
Pop off the triangular trim piece at the front edge of the window. Pops off easy with just a few spring clips retaining it.
Once that is off just remove 4 fasteners and disconnect the wiring harness.
Once the fasteners are off just lift up and out on the mirror, there is a retention clip at the top. Once the mirror is out there is nothing in the way.
The new mirror fit like a glove. This is dry fit before tightening the fasteners.
Jay870's Avatar
Jay870
Snug up the fasteners and connect the wiring harness. I could not find a torque spec for the fasteners, but they seem like they would be very easy to overtighten so be cautious. If anything I erred on the side of caution and went pretty light. I will check them in a few weeks.
They fit great.
OEM
Boost
OEM Signal
Boost Sequential Signal
Took the truck for a quick spin around the block. No unexpected vibrations or rattles from the housings or mirrors. Power adjustments work fine. Manual extension works just like OEM, and manual fold works just like OEM. If I had to nit pick I would say the OEM has a slightly more positive detent when folded and opened but that is about it.
We'll see how they hold up to some miles, weather and the doors being opened/closed a few hundred times, but as it stands I am very happy with the product.
Old Apr 5, 2024 | 05:27 PM
ibeb's Avatar
ibeb
Glad you got everything squared away. I had a set if their tow mirrors on my 2019 F150 for a couple years and had no issues. Pulled them off when my F350 arrived and sold them to another F150 owner.
Old Apr 6, 2024 | 08:06 AM
jackfordsd350's Avatar
jackfordsd350
Great info and writeup. Thanks for the post.
Old Apr 6, 2024 | 09:13 AM
traveldawg's Avatar
traveldawg
Great info and write up. Thanks!
Old Apr 6, 2024 | 09:52 AM
nitebreeze's Avatar
nitebreeze
Sounds good. Thanks for sharing. I have done the same thing to mirrors on other trucks.
Old Apr 6, 2024 | 10:00 AM
67_4_ME's Avatar
67_4_ME
Boost mirrors are very popular on the F150 site, If I was keeping my 22 F150 they were on my to-do list.
Old Apr 10, 2024 | 07:50 PM
Schatzman's Avatar
Schatzman
3rd Gear
The incident
thanks for the great reply, but I believe my problem is in the triangle end where it is bolted to the door frame. That seems to be where the motor is housed that folds the mirror and maybe extends the mirror too. Can't seem to get that apart.
DILLIGAF13
Sep 28, 2023 04:37 PM
34SF
Jun 1, 2021 03:57 PM
moonley
Nov 24, 2018 09:46 AM
robert_l_ross
Jul 29, 2016 10:11 AM
