2001 Excursion 7.3 no start
Old Apr 3, 2024 | 07:02 PM
millersrealestate's Avatar
millersrealestate
1st Gear
I had a rattle in my exhaust so I used a piece of wire to prevent it from hitting the heat shield. afterward it’ll fire up run about 1 sec then die. No WTS, no gauge movement with key on. Clearly the wiring of the exhaust shorted something. I removed the wire from the exhaust, can not find any blown fuses. Checked fuse 30, checked PCM diode, and checked 30 amp starter maxi fuse. Not sure where to go next or why basically grounding the exhaust to the frame caused this.
Old Apr 4, 2024 | 06:18 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You probably fried the GEM or the cluster if you have a 2002-2003 7.3 Excursion.
SCPerf
37
Feb 3, 2023 09:49 PM
2000powerhorse
Mar 28, 2016 05:29 PM
brutus67
Sep 1, 2014 01:14 AM
rpdwelding
Dec 31, 2009 02:46 PM
tigerj2
1997 - 2003 F150
Oct 27, 2003 10:44 AM
