thread locker on flywheel bolts
Old Apr 3, 2024 | 06:39 PM
Z Martin's Avatar
Z Martin
Hey I was wondering how important is thread locker on flywheel bolts? I recently finished a flywheel and clutch change on my 351 Cleveland/M5OD combo and realized I forgot to put thread locker on the bolts. I did torque the new ARP bolts to 85 lbs. I do know the original owner who put the engine in the truck did not use thread locker and used off the shelf bolts and grinded the heads down. I ask because I am a bit of a stickler for doing things correctly and can't stand I screwed up. Disassembling the truck again would be no fun.
Old Apr 4, 2024 | 09:01 AM
1Butcher's Avatar
1Butcher
If the holes are blind, I would not worry about it. If the holes go all the way through the crank, I would take them out and put some type of sealer/loctite on them.
I understand the use of loctite, but I believe a tight bolt/nut does not come loose. There are some exceptions where the environment needs loctite. They don't use loctite on rod, mains, and headbolts.
Old Apr 4, 2024 | 10:45 AM
Z Martin's Avatar
Z Martin
Thanks. Others I have spoke to agree it should be ok. I drove the truck for 7000 miles with the previous owners set up so I think it will be fine with the arp bolts.
Taymo
Sep 17, 2020 06:12 PM
obscurity
Jul 9, 2016 01:51 PM
damarble
16
Oct 25, 2012 09:56 AM
Chickenguts
General Diesel Discussion
Mar 2, 2009 02:36 AM
hster
Sep 12, 2004 01:05 AM
