Rear axle conversion questions
Old Apr 2, 2024 | 09:10 PM
Parispete's Avatar
Parispete
5th Gear
I have a 1995 2WD F-150 xlt si gle cab. I will have to see what axle I have in it and get back. The question is about rear hub brakes being changed with an axle with disc brakes? Is there another vehicle with disc brakes that will fit my truck? I also plan to make it a pozzy track as well.
Old Apr 2, 2024 | 10:09 PM
Conanski's Avatar
Conanski
The truck has an 8.8 axle, there are disc conversion kits for it and you can also DIY a kit using parts from other Ford vehicles. Some later vehicles also had a version of the same axle woth disc brakes but usually the wheel bolt pattern is different, the one exception in the 2005ish E150 cargo van.
Old Apr 9, 2024 | 12:27 PM
Parispete's Avatar
Parispete
5th Gear
Thanks for the advice. I am one that thinks more parts more problems. The conversion kits are fine, but I would like it to look original with rear disc. This E 150 sounds good. I will look into that. Thanks
Old Apr 9, 2024 | 12:49 PM
Hit Man X's Avatar
Hit Man X
Drums are fine. Just fix them and get on with life.
Old Apr 9, 2024 | 02:58 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What are you hoping to gain? You hardly use the rear brakes under normal braking. When you rotate the tires, you should be checking the brakes. Adjust the shoes if needed. Done.
Old Apr 9, 2024 | 04:31 PM
Edgethis's Avatar
Edgethis
I know alot of people, myself included, don't really like to faff around with drum brakes. It is t mind numbingly easy to do pads and rotors on most disc setups, compared to messing with springs and bits and such on the drums.
Also, some folks that have custom wheels like disc brakes for the looks.
Having done multiple disc brake kits on different vehicles, you're on the right train if thought with trying to get a factory style setup. Makes getting parts down the road super easy.
The Mustang uses an 8.8 amd has rear disc's.
Here's a company that makes kits that don't use GM calipers
This kit comes with almost everything:
https://jfabmachining.com/products/c...brake-kit-17in
This ones much cheaper. But you gotta source the brake parts yourself, and run 17" wheels:
https://jfabmachining.com/products/r...brake-kit-17in
If I didn't have an F super50 dually, I'd be considering one of these options myself.
Old Apr 9, 2024 | 04:44 PM
Conanski's Avatar
Conanski
All the vehicles I own now have rear disc brakes including the last 2 work trucks and it's pretty easy to see/feel the difference it makes when stopping on slippery/wet roads or when towing or hauling a load, I don't miss the front end slide these old trucks would do in those conditions because the rear drums weren't doing anything. That's not to say drum brakes are bad my dump trailer has them and they will easily lock the tires even when loaded, it's because of the mechanical auto adjusters that never stay working correctly for very long... in my experience.
Old Apr 9, 2024 | 05:22 PM
BLK79's Avatar
BLK79
My issue with rear disc brakes on trucks/vans (anything that tows potentially heavy) is drum brakes for parking brake, when adjusted properly, can't be matched with discs - at least my experience. Air disc (spring) brakes on class 8 trucks an exception.
Old Apr 9, 2024 | 05:26 PM
OBS460's Avatar
OBS460
On a 95 F150 that's 2wd and stock you are wasting your money.
97anny
1997 - 2003 F150
Jan 25, 2016 05:59 AM
desertwest
Feb 5, 2013 07:50 AM
TheRedPheonix
Oct 18, 2012 02:12 PM
fordfarmer
Jun 15, 2004 04:40 PM
Blue Truck
Mar 24, 2002 11:26 PM
