Trailer Wiring
Old Mar 31, 2024 | 02:18 PM
jeremybray750's Avatar
jeremybray750
5th Gear
Trailer Wiring
My truck has a 4 pin connecter under the truck. I can not find the correct wiring harness to replace this current harness. Are all of these trucks like this? I have 2 trucks and they both have this connector. Is there something I am missing? Does my truck still have the factory towing package? Is it aftermarket? I would like to replace my 7 pin connector without splicing wires.
Old Mar 31, 2024 | 02:28 PM
T-wood's Avatar
T-wood
I got that round 4 pin connector from Amazon. I'll attach a link to it in a moment fr my tablet.
I came up empty. I wired my personal e350 that didn't have the tow package. I found purchase history for everything except that one plug. After rereading your post you can replace the round 7 pin plug using one of these replacements.
Old Mar 31, 2024 | 03:22 PM
Old and soft's Avatar
Old and soft
My e99, 01, and 17 all came with a 4 and 7 pin connector from the factory. Curious if the brake and 12v circuits are present on your rig.
Old Mar 31, 2024 | 07:32 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Old Apr 1, 2024 | 06:19 AM
BillyBob69's Avatar
BillyBob69
Oddly enough my E99 didn't have the RV plug either. I sourced a harness from a slavage yard. It plugs in and replaced the current 4 pin . The harness unplugs/plugs in along the drivers side frame about 2ft from the back. I had to drop my spare tire to make the access easier. You will have to make or if you can, remove the plug bracket from the source vehicle. I got lucky and mine had it attached. Not sure if it bolted into place or riveted from factory where it mounts to the truck
Viper Pilot
Aug 11, 2023 07:24 PM
BryanStein
Apr 19, 2022 03:07 PM
FordTruckfan89
22
Jun 9, 2013 10:57 AM
FordTrucksKickGM
Jan 5, 2008 01:59 PM
remmers
Mar 11, 2004 07:37 AM
