Air-conditioning issues in 2005 Excursion
Old Jun 20, 2024 | 08:42 AM
  #31
Excurvelle's Avatar
Excurvelle
How is it at idle? Mine is cold on the road but in traffic and hot outside (95 degrees plus)it has trouble keeping up.
Old Aug 21, 2024 | 07:00 PM
  #32
Kriticos6969's Avatar
Kriticos6969
1st Gear
Originally Posted by anton5052
@Tylus
Thanks again Tylus, I was able to go through all 3 of these steps.
I cleaned the box with compressed air, it looked pretty clean on the inside portion of the box. I also removed a single shim from the Compressor clutch.
Reading the gauges, Im getting around 70 on the low side and just over 200 on the high side. So, it looks like I have a High low pressure reading, and a Low High pressure reading. Ambient temp was 93F.
Any thoughts ? The AC blows cold when while running over about 1500 RPM. At idle, the truck starts getting hot. Probe thermometer stuck in the vent reads 50F when running at high RPM, at Idle, the duct temp goes up over 60F Essentially, I have to rev the truck at a stop light to keep it blowing cold air.
sounds like the compressor is weak
dablack
Feb 13, 2021 10:35 AM
timbersteel
Jun 15, 2014 06:50 PM
Muffinman
Aerostar
26
Aug 21, 2010 02:21 PM
willworkforbeer
1983 - 2012 Ranger & B-Series
May 23, 2009 07:26 AM
mneal
1997 - 2003 F150
May 30, 2007 11:16 PM
