noise
Old Nov 25, 2003 | 01:53 PM
kitchcop's Avatar
kitchcop
noise
i have a 2002 ford explorer xls with a 4.0 between 2500 and 3000 rpm there is a noise that i can't pin point. it sound like a ratteling sound. I have checked all heat shields and they seem ok can any one help.
Old Nov 25, 2003 | 05:08 PM
emtabmm's Avatar
emtabmm
Check this out....
Article No. 02-8-1
ENGINE - 4.0L SOHC - RATTLE NOISE FROM PRIMARY CHAIN DRIVE AREA BETWEEN 2000-3000 RPM - COLD ENGINE OPERATION ONLY
NOISE - RATTLE NOISE FROM PRIMARY TIMING CHAIN DRIVE AREA BETWEEN 2000-3000 RPM - COLD ENGINE OPERATION ONLY - VEHICLES EQUIPPED WITH 4.0L SOHC ENGINE ONLY
Publication Date: APRIL 12, 2002
FORD: 1999-2002 EXPLORER
2001-2002 EXPLORER SPORT TRAC, EXPLORER SPORT, RANGER
MERCURY: 1999-2002 MOUNTAINEER
This article is being republished in its entirety to add Ranger to the Labor Time Table.
ISSUE:
Some vehicles equipped with the 4.0 SOHC (Single Over-Head Cam) engine may exhibit a Primary Timing Chain rattle noise. The noise is audible during hot and cold engine operation (but predominantly found on cold engines) under acceleration, typically at 2400-2500 rpm. To confirm presence of this noise, accelerate in 2nd gear between 2000 and 3000 rpm and listen for rattle noise that sounds similar to spark knock. This may be caused by the Primary Timing Chain Tensioner system.
ACTION:
Replace the Primary Timing Chain Tensioner, Chain Guide, Jackshaft and Crankshaft Sprockets with a Primary Timing Chain Tensioner Kit. The Kit includes an improved Primary Chain Tensioner, as well as updated Primary Chain Guide, Jackshaft, and Crankshaft Sprockets. Required fasteners, primary timing chain, and front cover gaskets are also included. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Verify the condition. Obtain the correct Primary Timing Chain Tensioner Kit and follow the instruction sheet supplied with the Kit.
Use Kit 2U3Z-6D256-AA (balance shaft engines) for:
1999-2001 4X4 Explorer/Mountaineer
2001-2002 4X4 Sport/Sport Trac
ALL 2002 Explorer/Mountaineer, except engine codes 2G-960-AA and 2G-964-AA.
Use Kit P/N 2U3Z-6D256-BA (non balance shaft engines) for:
1999-2001 4X2 Explorer/Mountaineer
2001-2002 4X2 Sport/Sport Trac
2002 MY Explorer/Mountaineer with engine codes 2G-960-AA and 2G-964-AA
ALL 2001-2002 Ranger
PART NUMBER PART NAME
2U3Z-6D256-AA Primary Timing Chain Tensioner Kit - Balance Shaft Engines
2U3Z-6D256-BA Primary Timing Chain Tensioner Kit - Non Balance Shaft Engines
WARRANTY STATUS:
Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
Old Nov 25, 2003 | 09:46 PM
kitchcop's Avatar
kitchcop
thanks for the tip I will give my ford dealer a call.
Old Nov 26, 2003 | 10:01 PM
echo5charlie's Avatar
echo5charlie
I have a 2001 sport trac and it makes a vibration noise when it is at idle, mostly when the vehicle comes to a stop still in gear. I took it to the ford dealer and the technician said it wasn't a problem. But the noise is very annoying.
Old Feb 19, 2004 | 12:30 AM
jaystersj's Avatar
jaystersj
Just wondering if you figured out that noise. You sound like you had the same problem mine has, sounds sort of like a chain dangling on the road at about 2700rpms
Old May 4, 2004 | 05:05 PM
Pizzabert's Avatar
Pizzabert
Noise
What a great site!
Question for all of you...
I have the same problem with the timing chain on my 02 Explorer. My dealer has identified it as the source of the "noise" after several painful visits. I was just told that the parts have been backordered for what could be a couple of months. Now to my question. How much (if any) damage am I doing to my car if I continue to drive it until it is repaired?
brianjordanf250
Apr 28, 2013 10:23 AM
mackl1
Oct 29, 2012 06:35 PM
jowilker
26
Feb 8, 2011 06:45 AM
mtgrzlyman
May 14, 2008 11:13 AM
r-kid
Jul 24, 2004 02:18 PM
