Suspension Upgrade Completed!
I purchased adjustable track bar, u-bolts and rear top plates with bump tangs from PMF. The first set of U-bolts I ordered for the front were too short (8.5”), I ended up using 9.5”
Bump stops were shot, so I replaced those with energy suspension stops.
Wheels: 17” Method 705 titanium BS 4.75”
Tires: Toyo Open Country RT trail 35x12
Slight rub on the plastic air dam of front bumper, I trimmed plastic corners.
I used WFO 2 degree shims up front but not in the rear. I wanted to check the angle before installing. It appears there is a 4 degree difference, now I wish I had used the 2 degree shims. I watched a video that suggested anything over 7 should be corrected. I have no vibrations, so do I leave it as is, use the 2 degree or go ahead and order 4 degree? I think having everything in line will help with longevity.
I did not follow the recommended alignment settings, I let the shop do their thing. Alignment has a 6 month / 6k warranty so if an issue arises I’ll take it back. My truck tracks straight and does not wonder.
The hardest part of the procedure was wrestling the springs back in solo with floor jacks. I had one stubborn bolt, but it only required a PB blaster soak, and a cheater bar.
The truck has 133k miles, it came with an old school super chips micro tuner. I was running stock, but now with the bigger wheels and tires, I’m running the middle tune, Perf - Tow. It definitely makes a difference. I’d like to keep it mild, but I’ll probably need to add cold air intake and exhaust, definitely an egt probe maybe and switch to a hydra to have more tuning options.
Here are a few pics! Thanks for reading.
Completed
Method 705 titanium 17” 4.75 BS Toyo R/T trail 35x12.5
Suspension with stock tires and wheels
Pro Comp 22210, Icon adjustable piggyback 2.5
Stock suspension, stock wheels
those Body Mounts made a Huge Difference in how the truck rides, the OEM mounts were completely destroyed.
Drove it to Boston from Long Island 2 weeks ago. 10 hrs round trip drove great but still has some wander . He’s going to do ball joints next, which hopefully will fix the problem. I listed all the upgrades on here recently. Otherwise, it drove fine.
Best of luck on your adventures. Thanks for sharing.
Red Head Steering pump
If anyone has better info please feel free to add,comment or disagree😀
How are you liking the tires? How much road noise?
