I am testing my pump for pressure and when I disconnected the Quick Connect lines that run from the high pressure pump to the cylinder heads, I had a small problem.
On the end of the line there is a rubber piece. I don't know what you call that, but it kind of looks like a dust seal. Well when I took my lines off that piece fell off. There is a clip that is underneath of that. The clip is still on there.
The piece fell down into the valley so I may be able to find it. I have not as of yet.
Can you buy just that piece? Can I reuse the other piece if I can find it?
