High pressure crossover line?
Old Sep 26, 2005 | 05:57 PM
PSNut's Avatar
PSNut
Was wondering if these lines are worth the investment.
Old Sep 26, 2005 | 06:21 PM
Kwikkordead's Avatar
Kwikkordead
Worth every penny IMO. It completly balances the HPOP pressures between the cylinder heads. Makes for a much smoother, quieter idle. No help in extra power. Just make sure that when you install the hose that it isn't "S" shaped when you tighten down the couplers. It needs to be a perfect upside down rainbow shaped when it's tighened down. Failure to make it that way will cause it to bubble and bleed oil at the end where the couplers are.
Of cource there is the solid line available now that wasn't when I bought mine..... I don't remember where to get it right now.
Old Sep 26, 2005 | 06:23 PM
1997F-350's Avatar
1997F-350
dale isley sells em and yes they are a good investment. truck just sounds better with it period.
Old Sep 26, 2005 | 07:05 PM
MRBASS's Avatar
MRBASS
I got my braided line from Dale and no leaks either.. Makes for a much smoother running engine for sure..
Old Sep 26, 2005 | 07:16 PM
HeatStroked's Avatar
HeatStroked
I had a crossover hose that began to leak around the fittings after a year or so.
I swtiched to the Stainless Steel HPX and no problems. ITPDiesel has them.
Old Sep 26, 2005 | 07:23 PM
PSNut's Avatar
PSNut
much thanks!
Hey Guys,
Thanks to all of u for the helpful info. I'm going to order one from ITP.
Old Sep 26, 2005 | 07:25 PM
PSNut's Avatar
PSNut
Dale?
Who's Dale?
Old Sep 26, 2005 | 11:43 PM
Jlower's Avatar
Jlower
Dale Isley at Tymar performance and happens to be one very knowledgeable diesel guy!
Old Nov 25, 2005 | 11:25 AM
edub32's Avatar
edub32
Does Tymar have a working website right now?? I've been searching for them but I just found a site under construction. ???
Old Nov 25, 2005 | 11:59 AM
Wings's Avatar
Wings
You know? I saw this addition and was wondering the same myself. I will check out ITP. Lucky post at the right time. Good going PSNut and thanks Kwik for the advice.
Old Nov 25, 2005 | 12:23 PM
PSNut's Avatar
PSNut
www.blackclouddiesel.com is carrying them now for $45 w/free shipping! look under their own products or click this link http://www.blackclouddiesel.com/Ford/ourfordstuff.htm
Old Nov 25, 2005 | 01:05 PM
Wings's Avatar
Wings
Thanks PsNut, The Black Cloud is the one I had orginally looked at. I can only find the one for 97 and before at ITP, and nothing from Tymar.
Old Nov 25, 2005 | 03:56 PM
HeatStroked
ITP sells the SS HPX 94-2003's. My original hose type from Diesel Manor began to leak after 8 months or so and I switched to the SS HPX. I have even removed it a couple of times to get to my turbo and re-installed it, still no leaks.
I highly recommend the SS HPX.
Old Nov 25, 2005 | 04:23 PM
Wings's Avatar
Wings
Thanks HeatStroked. I may have miss read the add. I'll check it out again. I do remember the picture and it seem to have an upward arch, I am assuming you don't have air bubble problems? Kwik mentioned to mount the (hose type) in a downward arch.
Old Nov 25, 2005 | 04:57 PM
Kwikkordead
If you have a '99 on it goes down into the valley. I think that the hard, stainless steel ones go over the top on the OBS trucks.
