Light wire diagram
Old Mar 27, 2024 | 09:07 PM
AzzMann's Avatar
AzzMann
Light wire diagram
I recently purchased a 85’ flareside. Have absolutely no lights coming on. Looks like rats had a feast. So I’m looking if anyone has a wire diagram for the lights headlights,brakes etc.
Old Mar 28, 2024 | 07:14 AM
Franklin2's Avatar
Franklin2
Any wire in any part of your truck can be found in the diagrams in this link. https://www.garysgaragemahal.com/1985-evtm.html
Old Mar 28, 2024 | 07:16 AM
Bronco638's Avatar
Bronco638
Edit: Dave beat me to it ^^
As the owner of an '80 Flare Side; Nice Truck!
Last edited by Bronco638; Mar 28, 2024 at 07:20 AM. Reason: another inmate posted pertinent info before I did.
Old Mar 28, 2024 | 08:54 AM
kr98664's Avatar
kr98664
And here's a troubleshooting guide that may help, too:
https://www.ford-trucks.com/forums/1...ing-guide.html
Pay close attention to the wiring diagrams in the first link. IIRC, the grounds for the rear lights are different with the flareside bed. If the bed is not well grounded, this can affect those lights.
Old Mar 28, 2024 | 08:55 AM
AzzMann's Avatar
AzzMann
Thank you Franklin!
bronco, just started to rebuild it and I’m in love lol when all said and done going to have a 2.5” lot with 33’s red with the “ford” on the tailgate going to be white
Old Mar 28, 2024 | 07:10 PM
FuzzFace2's Avatar
FuzzFace2
So 2.5" lift and 33" tires on a 4x2 truck?
You may want to look into that as lifting or lowering any of our trucks is not easy with the TIB / TTB front suspension.
You might be able to use a 4x4 lift kit for a 4x4 150 as the front suspension brackets should be the same between the 100 / 150 trucks.
You will need the drop brackets for the radius arms and beam pivot.
Only good thing is the 85 has ball joints so you can get the parts needed to adjust the suspension back to spec.
You did not say what motor, transmission and rear type & gear ratio the truck has as that may not work good with the 33" tires.
Also with the motor what wiring you may need or get rid of like if it has a 300 six.
Tail light ground dose not run to the front firewall like the style side trucks. Because of the wood bed the ground will be fun you should run a wire from the lights to the frame and up front the battery should go to the motor / frame and motor to firewall. If you have it run like that you will not have any issues.
For the letters on the tail gate you may want to look on Ebay for reflective ones to add more "see me at night" at the rear.
Day time
Evening with flash
The plate on my truck is mounted in the right place with the right bracket I dont know if our member is still making them or not look up top in the stickies.
There is also a light that was also used on different cars it is just in different colors.
After a 4 year cab off frame rebuild and some custom touches added I know (my) flare side pretty good.
BTW it looks like you are starting off with a nice truck.
Dave ----
TritonTamer
May 6, 2023 07:03 PM
N8RdaGR8R
Apr 6, 2019 01:52 PM
papabear1941
1947 and Older Ford Trucks
Apr 6, 2019 10:30 AM
hot-rod
13
Oct 28, 2016 08:02 PM
kjg26
Electrical Systems/Wiring
Nov 18, 2006 11:49 PM
