Tricks you have learned
When I load the parts catapult it indicates that I haven't done adequate troubleshooting, either I don't know how or am lacking the proper istrumentation or money to purchase said tools and or equipment. I might even be flat out guessing without a clue all the way up to a good educated guess.
When proper testing and evaluation of the problem points to a specific part I do not consider that part purchase to be loading the parts catapult.
I do have a little clue what the cause might be when checking but it could lead to more then 1 part being bad.
Kind of happened when I had a miss under load. I ended up doing a full tune up, pickup coil and main coil change and a carb change, I had the carb on the shelf.
Dave ----
(Pause for laughter to die down)
I often joke about loading the parts catapult (Pull!) in lieu of actual troubleshooting, but there are several factors to consider. In no particular order:
Is the part difficult to change?
Is the part expensive?
Is the part a normal consumable item (i.e. a fuel filter or distributor cap) that gets changed as routine preventative maintenance anyway?
Let's say you're getting a light chugging at freeway speed and you suspect a fuel delivery problem. Changing the fuel filter would be a reasonable guess. In theory, one could rig up a fuel pressure gauge, make some test runs, and then probably end up changing the filter anyway. In a simple case like that, going straight to a filter change is a good course of action. The part is cheap, easy to replace, and is intended to be changed on a regular schedule. If that doesn't fix the problem, trying a fuel pump might even be a good idea. Still fairly inexpensive, easy to change, and they certainly don't last forever. But that's about where I'd draw the line of shooting from the hip. If a new filter and pump don't fix it, then it's time to investigate further. I suppose if you had a known-good spare carb sitting on your shelf, you could try that, but I certainly wouldn't spend several hundred dollars on a reman just yet.
The preceding example was all fine and dandy. But sadly, how many times have we seen examples of catapult (Pull!) usage like the following?:
The engine won't start, so the battery gets replaced. Hmm, that didn't do it, so back to the store for a $79 starter with a lifetime warranty. It must be good if guaranteed forever, right? Hmm, still no joy. How about a new starter relay. Still no workee. Maybe it's bad spark plugs and wires? How about a distributor cap? We've change all the electrical parts. Could it be the carb? And so it goes... We can laugh, but it is VERY common for guys to throw all sorts of expensive parts at a problem in hopes of a fix. Meanwhile, the original problem still exists, but with the added likelihood of introducing a new fault with all that frantic parts swapping.
Wish I could find the study, but I remember a college class (Univ of Colorado?) did a controlled blind test of local mechanics. This was the late 70s, IIRC. (My brother knew the people who ran the study.) They used a VW Beetle, a common car at the time. They deliberately loosened the alternator drive belt, which is a simple, common fault. With the belt slipping and the charging system not up to par, the battery slowly ran down. The only visible symptom was slow cranking of the starter. A student brought the car to various mechanics and reported only that the car was hard to start. In return, they got all sorts of diagnoses. About half of the shops correctly diagnosed the loose belt and the resulting low battery. The rest wanted to change the battery, starter, etc.
https://youtube.com/watch?v=YEmPuvQiAbY
Who said a cannon? That's far too rough on the parts when fired. Suppose it is all moot, as the forces imparted at the destination are all similar.
FWIW, none of these options seems to have any advantage over the others as far as being effective repair techniques.
https://en.wikipedia.org/wiki/Trebuchet
Also yes, sometimes throwing parts at the problem can work good, hell a broken watch is right twice a day. Don't forget that these old girls are simple creatures, need 3 things to make go. Start with your fire triangle and work out the systems from there. Oversimplification, sure but that's part of the fun, Occam's Razor works better then any Gillette I've owned over the years. Need a easier metaphor, fine I have those in stock as well... Use the KISS system - Keep It Simple Stupid, would hate to create a ID-10T code while digging into the wrong system.
Secondly, a notable mention for brakes, when replacing calipers for whatever reason, take a hard look at the rubber line, or consider replacing with it. Adds $40 to brake job per wheel, but what happens is part of the inside of the line will brake away and create a check-valve in your line, allowing fluid to apply but not return, leading to premature pad wear. On the same system, brake fluid is hydroscopic, it will pull moisture from the air. Water and hydraulic systems don't mesh well, so every couple of years think about flushing the lines and getting new fluid in there. Using the Gatorade bottle bleeder just bleed off / replenish with new, until you get good fluid at valve.
