Oil leak
Old Mar 22, 2024 | 06:18 PM
Junktownbill99's Avatar
Junktownbill99
Oil leak
Hey there, anyone else have a leak similar to this? None on drive belt or fan.
and what are those lines running in the frame there?
Old Mar 22, 2024 | 06:26 PM
My4Fordtrucks's Avatar
My4Fordtrucks
No. What color fluid is leaking?
Power steering return line. If you looked to see where it connected: it goes from the steering gear to the power steering pump.
Old Mar 23, 2024 | 05:33 PM
Junktownbill99
Will still update, but a bit late, currently dumping rain ​​​​​​
Old Mar 23, 2024 | 08:13 PM
matkinson13's Avatar
matkinson13
My valve cover gaskets and oil pan gasket were leaking pretty good and Freeda's underside looks like yours. I installed new valve cover gaskets (replaced what I think were the originals!) and tightened the oil pan bolts (most were loose). Oil leak has lessened.
My advice is to look at the oil pan and valve cover gaskets and address those as necessary. That should be a good start.
Old Mar 23, 2024 | 08:43 PM
Junktownbill99
Thanks, wonder why they do that, cooling maybe
Old Mar 23, 2024 | 08:45 PM
Junktownbill99
Hmm, my cover gaskets are definitely leaking a bit, but I didn't think they'd do this, I'll take a closer look at the oil pan though
Old Mar 24, 2024 | 05:20 AM
My4Fordtrucks
Yes.
I’ll ask again… what fluid is leaking? It does not look like antifreeze so is it oil or transmission fluid?
Old Mar 24, 2024 | 11:26 AM
Junktownbill99
Meaning to get back to you about that, if it doesn't rain, I'll run out in a bit and take a look, I'm like 85% sure it's oil though.
Old Mar 24, 2024 | 01:42 PM
eric79xxl's Avatar
eric79xxl
5th Gear
i have leak in the same spot. no clue where it's coming from either.
Old Mar 24, 2024 | 05:20 PM
Junktownbill99
Photo dump
Definitely oil for the most part
Driver side oil pan seems to be the worst
Doesn't seem bad enough to worry about here
Where it's running along to the front I assume
Some by the tranny, but clutch doesn't slip, so not too worried about this
Just another photo of the leakage from the front
Much cleaner side of oil pan. (Passenger)
Looks like I know what I'm doing this summer. no fun stuff I guess ​​​​​​
Hyakkimaru
19
Mar 27, 2022 04:14 PM
Bobp67
Mar 11, 2021 05:18 AM
phantomphixer
Jul 17, 2014 12:20 AM
alvald83
Aug 6, 2010 11:11 AM
